Description
I am trying to serialize an engine, save it to file, and then later load the engine from and deserialize it.
I saw the documentation on this, which suggests:
IHostMemory *serializedModel = engine->serialize();
// store model to disk
serializedModel->destroy();
And for loading:
IRuntime* runtime = createInferRuntime(gLogger);
ICudaEngine* engine = runtime->deserializeCudaEngine(modelData, modelSize, nullptr);
I also looked at this blog post which also discusses serializing and deserializing the engine.
Finally, I found this github issue which shows someone doing this in a Windows environment.
I then attempted to do this with the MNist ONNX example.
I added the following to the top of my code:
std::string engineFile = "SerializedEngineTest.engine";
bool serializeEngine = false;
And in the main routine:
if (serializeEngine) {
if (!sample.build())
return gLogger.reportFail(sampleTest);
else {
if (!sample.derserializeEngineFromFile())
I defined two functions:
bool SampleOnnxMNIST::build()
auto builder = SampleUniquePtr<nvinfer1::IBuilder>(nvinfer1::createInferBuilder(gLogger.getTRTLogger()));
if (!builder)
return false;
const auto explicitBatch = 1U << static_cast<uint32_t>(NetworkDefinitionCreationFlag::kEXPLICIT_BATCH);
auto network = SampleUniquePtr<nvinfer1::INetworkDefinition>(builder->createNetworkV2(explicitBatch));
if (!network)
return false;
auto config = SampleUniquePtr<nvinfer1::IBuilderConfig>(builder->createBuilderConfig());
if (!config)
return false;
auto parser = SampleUniquePtr<nvonnxparser::IParser>(nvonnxparser::createParser(*network, gLogger.getTRTLogger()));
if (!parser)
return false;
auto constructed = constructNetwork(builder, network, config, parser);
if (!constructed)
return false;
mEngine = std::shared_ptr<nvinfer1::ICudaEngine>(
builder->buildEngineWithConfig(*network, *config), samplesCommon::InferDeleter());
if (!mEngine)
gLogInfo << "false engine..?" << std::endl;
return false;
// Serialize engine and save to file
std::ofstream p(engineFile.c_str(), std::ios::binary);
IHostMemory* m_ModelStream = mEngine->serialize();
p.write(reinterpret_cast<const char*>(m_ModelStream->data()), m_ModelStream->size());
p.close();
gLogInfo << "network->getNbInputs()" << network->getNbInputs() << std::endl;
assert(network->getNbInputs() == 1);
mInputDims = network->getInput(0)->getDimensions();
gLogInfo << "mInputDims = " << mInputDims << std::endl;
gLogInfo << "mInputDims.nbDims = " << mInputDims.nbDims << std::endl;
assert(mInputDims.nbDims == 4);
gLogInfo << "network->getNbOutputs() = " << network->getNbOutputs() << std::endl;
gLogInfo << "network->getOutput(0)->getDimensions() = " << network->getOutput(0)->getDimensions() << std::endl;
assert(network->getNbOutputs() == 1);
mOutputDims = network->getOutput(0)->getDimensions();
gLogInfo << "mOutputDims = " << mOutputDims << std::endl;
gLogInfo << "mOutputDims.nbDims = " << mOutputDims.nbDims << std::endl;
assert(mOutputDims.nbDims == 2);
return true;
And:
bool SampleOnnxMNIST::derserializeEngineFromFile()
// Load engine from file and de-serialize
std::vector<char> trtModelStreamfromFile;
size_t size{ 0 };
std::ifstream file(engineFile, std::ios::binary);
if (file.good())
file.seekg(0, file.end);
size = file.tellg();
file.seekg(0, file.beg);
trtModelStreamfromFile.resize(size);
file.read(trtModelStreamfromFile.data(), size);
file.close();
IRuntime* runtime = createInferRuntime(gLogger.getTRTLogger());
ICudaEngine* mEngine = runtime->deserializeCudaEngine(trtModelStreamfromFile.data(), size, nullptr);
if (!mEngine)
return false;
return true;
When I set
bool serializeEngine = true;
and run the program, it saves to file.
When I set:
and run the program, in the derserializeEngineFromFile() method, on the line:
if (!mEngine)
I am noticing that mEngine is empty.
What am I doing incorrectly?
Environment
TensorRT Version: 7.0
CUDA Version: 10.2
CUDNN Version: 7.6.5
Operating System + Version: Windows 10 64-bit
Visual Studio Version: 2019
