Jetson Xavier Nx
• DeepStream Version
5.0
Output of “cat /etc/nv_tegra_release” command as:
R32 (release), REVISION: 4.2, GCID: 20074772, BOARD: t186ref, EABI: aarch64, DATE: Thu Apr 9 01:26:40 UTC 2020
• TensorRT Version
7.1
I have engine file (e.g. yolov4.engine) based on “TensorRT API to generate the network from scratch” and add all non-supported layers as a plugin (in shared library form e.g. libcustomlayerplugin.so). I’ve used following command to verify general working
/usr/src/tensorrt/bin/trtexec --loadEngine=./yolov4.engine --plugins=./liblayerplugin.so
&&&& RUNNING TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --loadEngine=./yolov4.engine --plugins=./liblayerplugin.so
[08/21/2020-16:18:32] [I] === Model Options ===
[08/21/2020-16:18:32] [I] Format: *
[08/21/2020-16:18:32] [I] Model:
[08/21/2020-16:18:32] [I] Output:
[08/21/2020-16:18:32] [I] === Build Options ===
[08/21/2020-16:18:32] [I] Max batch: 1
[08/21/2020-16:18:32] [I] Workspace: 16 MB
[08/21/2020-16:18:32] [I] minTiming: 1
[08/21/2020-16:18:32] [I] avgTiming: 8
[08/21/2020-16:18:32] [I] Precision: FP32
after some other messages I get below
08/21/2020-16:18:41] [I] GPU Compute
[08/21/2020-16:18:41] [I] min: 68.1166 ms
[08/21/2020-16:18:41] [I] max: 85.4661 ms
[08/21/2020-16:18:41] [I] mean: 73.632 ms
[08/21/2020-16:18:41] [I] median: 74.3506 ms
[08/21/2020-16:18:41] [I] percentile: 85.4661 ms at 99%
[08/21/2020-16:18:41] [I] total compute time: 2.57712 s
&&&& PASSED TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --loadEngine=./yolov4.engine --plugins=./liblayerplugin.so
For integration in SDK I have set the following fields in config_infer_primary.txt (adapted from config_infer_primary_yoloV3.txt):
This is what goes in the file:
model-engine-file=yolov4.engine
custom-lib-path=libcustomlayerplugin.so
so that custom plugin (libcustomlayerplugin.so) can be registered with TensorRT runtime via dlopen of Gst-nvinfer.
The other libraries are provided on the commandline itself as
LD_PRELOAD=“libnvds_infercustomparser_yolov3_tlt.so libnvinfer_plugin.so.7.1.3” ./deepstream-app -c deepstream_app_source1_detection_models.txt
With that arrangement, I get errors below. What is the best way to integrate “scratch TensorRT API network + non-supported layer plugin” with deepstream. It sounds like custom-lib-path can take only one file but multiple shared libraries needs to be registered with TensorRT via Gst-nvinfer.
Regards,
Ghazni
I get below errors:
Unknown or legacy key specified ‘is-classifier’ for group [property]
Opening in BLOCKING MODE
Using winsys: x11
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
gstnvtracker: Past frame output is OFF
0:00:05.998213168 25695 0x55bd52e920 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/home/mgsaeed/nvme/iva-20.08/samples/models/tlt_pretrained_models/yolov4/yolov4.engine
INFO: [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT data 3x608x608
1 OUTPUT kFLOAT prob 7001x1x1
0:00:05.998445747 25695 0x55bd52e920 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 1]: Use deserialized engine model: /home/mgsaeed/nvme/iva-20.08/samples/models/tlt_pretrained_models/yolov4/yolov4.engine
0:00:06.177443429 25695 0x55bd52e920 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initResource() <nvdsinfer_context_impl.cpp:683> [UID = 1]: Detect-postprocessor failed to init resource because dlsym failed to get func NvDsInferParseCustomYOLOV3TLT pointer
ERROR: Infer Context failed to initialize post-processing resource, nvinfer error:NVDSINFER_CUSTOM_LIB_FAILED
ERROR: Infer Context prepare postprocessing resource failed., nvinfer error:NVDSINFER_CUSTOM_LIB_FAILED
0:00:06.246481893 25695 0x55bd52e920 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start:<primary_gie> error: Failed to create NvDsInferContext instance
0:00:06.246593734 25695 0x55bd52e920 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start:<primary_gie> error: Config file path: /home/mgsaeed/nvme/iva-20.08/samples/configs/tlt_pretrained_models/config_infer_primary_yolov4.txt, NvDsInfer Error: NVDSINFER_CUSTOM_LIB_FAILED
** ERROR: main:655: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Failed to create NvDsInferContext instance
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(809): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
App run failed
