Sdkmanager install on host machine (Ubuntu 22.04) fails
Downloaded sdkmanager_2.1.0-11698_amd64.deb into my /home/jonathan/Downloads folder and proceeded with:
sudo apt install ./sdkmanager_[version]-[build#]_amd64.deb
and this happened…
jonathan@jonathan-M32CD-A-F-K20CD-K31CD:~/Downloads$ sudo apt install ./sdkmanager_2.1.0-11698_amd64.deb
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
Note, selecting ‘sdkmanager’ instead of ‘./sdkmanager_2.1.0-11698_amd64.deb’
The following additional packages will be installed:
libcanberra-gtk-module libcanberra-gtk0
The following NEW packages will be installed:
libcanberra-gtk-module libcanberra-gtk0 sdkmanager
0 upgraded, 3 newly installed, 0 to remove and 23 not upgraded.
Need to get 19.3 kB/89.0 MB of archives.
After this operation, 386 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 Index of /ubuntu jammy-updates/universe amd64 libcanberra-gtk0 amd64 0.30-10ubuntu1.22.04.1 [8,286 B]
Get:2 Index of /ubuntu jammy-updates/universe amd64 libcanberra-gtk-module amd64 0.30-10ubuntu1.22.04.1 [11.0 kB]
Get:3 /home/jonathan/Downloads/sdkmanager_2.1.0-11698_amd64.deb sdkmanager amd64 2.1.0-11698 [89.0 MB]
Fetched 19.3 kB in 1s (29.1 kB/s)
Selecting previously unselected package libcanberra-gtk0:amd64.
(Reading database … 179822 files and directories currently installed.)
Preparing to unpack …/libcanberra-gtk0_0.30-10ubuntu1.22.04.1_amd64.deb …
Unpacking libcanberra-gtk0:amd64 (0.30-10ubuntu1.22.04.1) …
Selecting previously unselected package libcanberra-gtk-module:amd64.
Preparing to unpack …/libcanberra-gtk-module_0.30-10ubuntu1.22.04.1_amd64.deb …
Unpacking libcanberra-gtk-module:amd64 (0.30-10ubuntu1.22.04.1) …
Selecting previously unselected package sdkmanager.
Preparing to unpack …/sdkmanager_2.1.0-11698_amd64.deb …
Unpacking sdkmanager (2.1.0-11698) …
Setting up libcanberra-gtk0:amd64 (0.30-10ubuntu1.22.04.1) …
Setting up libcanberra-gtk-module:amd64 (0.30-10ubuntu1.22.04.1) …
Setting up sdkmanager (2.1.0-11698) …
Processing triggers for hicolor-icon-theme (0.17-2) …
Processing triggers for gnome-menus (3.36.0-1ubuntu3) …
Processing triggers for libc-bin (2.35-0ubuntu3.8) …
Processing triggers for mailcap (3.70+nmu1ubuntu1) …
Processing triggers for desktop-file-utils (0.26-1ubuntu3) …
N: Download is performed unsandboxed as root as file ‘/home/jonathan/Downloads/sdkmanager_2.1.0-11698_amd64.deb’ couldn’t be accessed by user ‘_apt’. - pkgAcquire::Run (13: Permission denied)
How do I grant user _apt permissions?
Tried: sudo chown _apt /home/jonathan/Downloads/
and a reinstall but no luck.
HELP!
Jon
What is the result of sudo dpkg -i sdkmanager_2.1.0-11698_amd64.deb on this host PC?
onathan@jonathan-M32CD-A-F-K20CD-K31CD:~/Downloads$ sudo dpkg -i sdkmanager_2.1.0-11698_amd64.deb
[sudo] password for jonathan:
(Reading database … 194385 files and directories currently installed.)
Preparing to unpack sdkmanager_2.1.0-11698_amd64.deb …
Unpacking sdkmanager (2.1.0-11698) over (2.1.0-11698) …
Looks like got installed?
It did not. But the SDK Manager icon appeared but does nothing when clicked.
I don’t know what icon you are talking about.
Open a terminal and run command sdkmanager and tell us what happened on your side.
If you right click on this icon, does it have something like “properties” you can see? Perhaps it shows what it is linked against. Also, on your regular user in a GUI console, does it work if you simply type sdkmanager?
