I bought a new laptop yesterday and installed Ubuntu 23.04 for dual boot with Windows. No matter what I do, I haven’t yet been able to make Ubuntu detect my second monitor, which I connect through HDMI. After plugging the cable in, the monitor just quickly shows “HDMI NO SIGNAL” after a few seconds and then goes blank again. The monitor is automatically detected in Windows – it works without any problems there.
Some information about my setup:
- the laptop is HP ZBook Power 15.6 inch G9 Mobile Workstation with NVIDIA RTX A1000 Laptop GPU
- output of
xrandr --listprovidersis
Providers: number : 2
Provider 0: id: 0x217 cap: 0x1, Source Output crtcs: 0 outputs: 0 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x23f cap: 0x6, Sink Output, Source Offload crtcs: 4 outputs: 5 associated providers: 1 name:modesetting
- output of
xrandr --listmonitorsis
Monitors: 1
0: +*eDP-1-1 1920/344x1080/194+0+0 eDP-1-1
- output of
dpkg -l | grep -i nvidia
ii libnvidia-cfg1-535:amd64 535.54.03-0ubuntu0.23.04.2 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-535 535.54.03-0ubuntu0.23.04.2 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-535:amd64 535.54.03-0ubuntu0.23.04.2 amd64 NVIDIA libcompute package
ii libnvidia-decode-535:amd64 535.54.03-0ubuntu0.23.04.2 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-535:amd64 535.54.03-0ubuntu0.23.04.2 amd64 NVENC Video Encoding runtime library
ii libnvidia-extra-535:amd64 535.54.03-0ubuntu0.23.04.2 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-535:amd64 535.54.03-0ubuntu0.23.04.2 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-535:amd64 535.54.03-0ubuntu0.23.04.2 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii nvidia-compute-utils-535 535.54.03-0ubuntu0.23.04.2 amd64 NVIDIA compute utilities
ii nvidia-dkms-535 535.54.03-0ubuntu0.23.04.2 amd64 NVIDIA DKMS package
ii nvidia-driver-535 535.54.03-0ubuntu0.23.04.2 amd64 NVIDIA driver metapackage
ii nvidia-firmware-535-535.54.03 535.54.03-0ubuntu0.23.04.2 amd64 Firmware files used by the kernel module
ii nvidia-kernel-common-535 535.54.03-0ubuntu0.23.04.2 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-535 535.54.03-0ubuntu0.23.04.2 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA's Prime
ii nvidia-settings 510.47.03-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-535 535.54.03-0ubuntu0.23.04.2 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18.3 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-535 535.54.03-0ubuntu0.23.04.2 amd64 NVIDIA binary Xorg driver
this is what my NVIDIA Settings look like:
nvidia-bug-report.log.gz_pls_change_extension.txt (387.3 KB)
What I’ve tried (mostly based on information I found on this forum) without any success:
sudo prime-select nvidia- purging all the NVIDIA drivers and reinstalling them with
sudo apt install nvidia-driver-535 - selecting “NVIDIA (Performance Mode)” in NVIDIA Settings > PRIME Profiles
- commenting out
Option "IgnoreDisplayDevices" "CRT"in/usr/share/X11/xorg.conf.d/11-nvidia-prime.confand disabling gpu-manager (GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nogpumanager"in/etc/default/grub) to not overwrite the change - switch from gdm3 to lightdm using
sudo apt install lightdm
Any help would be much appreciated. Thank you.
