Hi All,
I am new to CUDA. I have looked through the basic tutorials and programming guide and have done some simple tests.
Now I want to use CUDA to accelerate part of my program.
What I want to achieve is to use CUDA to solve a simple PDE like
D(phi)/dt = S(phi)(grad(phi) -1)
I have previously implemented it in C++ and it turns out to be most time consuming because of the large number of grid points involved. This equation has to be time
integrated for 20 steps. That’s 20 loops over grid points on the order of 1 million.
I think CUDA will help since for each time step, each grid point is independent of others.
Could anyone give me some suggestions as to how to implement it? A brief workflow will be good.
The most important issue is how to map data (3D array) to device memory. Shall I use 3D texture? How to set the execution configuration?
Thanks,
Bin
