SegFormer Backbones Available
• Hardware (T4/V100/Xavier/Nano/etc) A6000
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc) Segformer
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
Hi
Slightly confused by TAO4.01; in earlier versions you download a pretrained model as the backbone. In version 4.01 i was trying to use the segformer model and appears that you specify the backbone in the spec file for training?
Cheers
For 4.0.1
it is the same as 4.0.0.
model_config:
pretrained: /path/to/your-pretrained-backbone-model
backbone:
type: “mit_b5”
