When I run my python file on jetson xavier this error shows up
this code has a opencv, torch, pyzed and numpy libraries. How can i fix that
Hi @gurselturkeri, can you try running this: python3 -c 'import numpy'
If that makes the same error, can you try this?
it still shows same error
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
If you run OPENBLAS_CORETYPE=ARMV8 python3 -c 'import numpy' does it produce the error?
