Hi all
I have the following problem on a freshly installed Jetson Nano when I call cv2.namedWindow(‘test’).
This is a minimal program to reproduce the problem:
import cv2
cv2.namedWindow('test')
GLib-CRITICAL **: 16:07:09.319: g_once_init_leave: assertion ‘result != 0’ failed
I have installed tensorflow as per the instructions on the Jetson to overcome the initial “ImportError: numpy.core.multiarray failed to import”
This is under python 3.6 (there is no such error on python2)
Full stack below:
(python3.6:7732): GLib-GObject-WARNING **: 16:07:09.319: cannot register existing type 'GdkDisplayManager'
(python3.6:7732): GLib-CRITICAL **: 16:07:09.319: g_once_init_leave: assertion 'result != 0' failed
(python3.6:7732): GLib-GObject-CRITICAL **: 16:07:09.319: g_object_new_with_properties: assertion 'G_TYPE_IS_OBJECT (object_type)' failed
(python3.6:7732): GLib-GObject-WARNING **: 16:07:09.319: invalid (NULL) pointer instance
(python3.6:7732): GLib-GObject-CRITICAL **: 16:07:09.319: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(python3.6:7732): GLib-GObject-WARNING **: 16:07:09.325: cannot register existing type 'GdkDisplay'
(python3.6:7732): GLib-CRITICAL **: 16:07:09.325: g_once_init_leave: assertion 'result != 0' failed
(python3.6:7732): GLib-GObject-CRITICAL **: 16:07:09.325: g_type_register_static: assertion 'parent_type > 0' failed
(python3.6:7732): GLib-GObject-CRITICAL **: 16:07:09.325: g_object_new_with_properties: assertion 'G_TYPE_IS_OBJECT (object_type)' failed
Other parts of opencv seem to be fine (in terms of reading/resizing images), but I cannot display them. I can use matplotlib, but I have feeling this will probably bite me later when I’m trying to grab images from a camera.
Any help would be greatly appreciated.
Many thanks
Mark
