Hi. I am currently trying to deploy DetectNet placed under dusty-nv’s jetson-inference repo. In the PGIE-FP16-CarType-CarMake-CarColor.txt file, I’m changing the parameters model-file=/home/nvidia/jetson-inference/data/networks/bvlc_googlenet.caffemodel, proto-file=/home/nvidia/jetson-inference/data/networks/detectnet.prototxt and labelfile-path=/home/nvidia/jetson-inference/data/networks/ilsvrc12_synset_words.txt but not changing the num-classes under the [primary-gie] section. This way, I’m getting “Segmentation fault (core dumped)” error. What should I do to run a custom network? Thanks in advance.
Hi Doruk,
Is it possible to share your model to let us reproduce on my side?
wayne zhu
Of course. Here:
# DetectNet network
# Data/Input layers
layer {
type: "Data"
top: "data"
data_param {
backend: LMDB
source: "examples/kitti/kitti_train_images.lmdb"
batch_size: 10
include: { phase: TRAIN }
layer {
type: "Data"
top: "label"
data_param {
backend: LMDB
source: "examples/kitti/kitti_train_labels.lmdb"
batch_size: 10
layer {
type: "Data"
top: "data"
data_param {
backend: LMDB
source: "examples/kitti/kitti_test_images.lmdb"
batch_size: 6
include: { phase: TEST stage: "val" }
layer {
type: "Data"
top: "label"
data_param {
backend: LMDB
source: "examples/kitti/kitti_test_labels.lmdb"
batch_size: 6
layer {
type: "Input"
top: "data"
input_param {
shape {
dim: 1
dim: 3
dim: 640
dim: 640
include: { phase: TEST not_stage: "val" }
# Data transformation layers
layer {
type: "DetectNetTransformation"
bottom: "data"
bottom: "label"
top: "transformed_data"
top: "transformed_label"
detectnet_groundtruth_param: {
stride: 16
scale_cvg: 0.4
gridbox_type: GRIDBOX_MIN
coverage_type: RECTANGULAR
min_cvg_len: 20
obj_norm: true
image_size_x: 640
image_size_y: 640
crop_bboxes: false
object_class: { src: 1 dst: 0} # obj class 1 -> cvg index 0
detectnet_augmentation_param: {
crop_prob: 1
shift_x: 32
shift_y: 32
flip_prob: 0.5
rotation_prob: 0
max_rotate_degree: 5
scale_prob: 0.4
scale_min: 0.8
scale_max: 1.2
hue_rotation_prob: 0.8
hue_rotation: 30
desaturation_prob: 0.8
desaturation_max: 0.8
transform_param: {
mean_value: 127
layer {
bottom: "data"
bottom: "label"
stride: 16
scale_cvg: 0.4
min_cvg_len: 20
obj_norm: true
image_size_x: 640
image_size_y: 640
crop_bboxes: false
transform_param: {
mean_value: 127
layer {
type: "Power"
bottom: "data"
power_param {
shift: -127
# Label conversion layers
layer {
type: "Slice"
bottom: "transformed_label"
top: "foreground-label"
top: "bbox-label"
top: "size-label"
top: "obj-label"
top: "coverage-label"
slice_param {
slice_dim: 1
slice_point: 1
slice_point: 5
slice_point: 7
slice_point: 8
include { phase: TRAIN }
include { phase: TEST stage: "val" }
layer {
type: "Concat"
bottom: "foreground-label"
top: "coverage-block"
concat_param {
concat_dim: 1
layer {
type: "Concat"
bottom: "size-label"
top: "size-block"
concat_param {
concat_dim: 1
layer {
type: "Concat"
bottom: "obj-label"
bottom: "obj-label"
bottom: "obj-label"
bottom: "obj-label"
top: "obj-block"
concat_param {
concat_dim: 1
layer {
type: "Eltwise"
bottom: "bbox-label"
bottom: "size-block"
top: "bbox-label-norm"
eltwise_param {
operation: PROD
layer {
type: "Eltwise"
bottom: "bbox-label-norm"
bottom: "obj-block"
top: "bbox-obj-label-norm"
eltwise_param {
operation: PROD
# Start of convolutional network
layer {
type: "Convolution"
bottom: "transformed_data"
top: "conv1/7x7_s2"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 3
kernel_size: 7
stride: 2
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "conv1/7x7_s2"
top: "conv1/7x7_s2"
layer {
type: "Pooling"
top: "pool1/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "LRN"
bottom: "pool1/3x3_s2"
top: "pool1/norm1"
lrn_param {
local_size: 5
alpha: 0.0001
beta: 0.75
layer {
type: "Convolution"
bottom: "pool1/norm1"
top: "conv2/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "conv2/3x3_reduce"
layer {
type: "Convolution"
top: "conv2/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 192
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "conv2/3x3"
top: "conv2/3x3"
layer {
type: "LRN"
bottom: "conv2/3x3"
top: "conv2/norm2"
lrn_param {
local_size: 5
alpha: 0.0001
beta: 0.75
layer {
type: "Pooling"
bottom: "conv2/norm2"
top: "pool2/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
bottom: "pool2/3x3_s2"
top: "inception_3a/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3a/1x1"
layer {
type: "Convolution"
top: "inception_3a/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 96
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3a/3x3_reduce"
layer {
type: "Convolution"
top: "inception_3a/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3a/3x3"
layer {
type: "Convolution"
top: "inception_3a/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3a/5x5_reduce"
layer {
type: "Convolution"
top: "inception_3a/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3a/5x5"
layer {
type: "Pooling"
top: "inception_3a/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_3a/pool"
top: "inception_3a/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3a/pool_proj"
layer {
type: "Concat"
top: "inception_3a/output"
layer {
type: "Convolution"
bottom: "inception_3a/output"
top: "inception_3b/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3b/1x1"
layer {
type: "Convolution"
top: "inception_3b/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3b/3x3_reduce"
layer {
type: "Convolution"
top: "inception_3b/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 192
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3b/3x3"
layer {
type: "Convolution"
top: "inception_3b/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3b/5x5_reduce"
layer {
type: "Convolution"
top: "inception_3b/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 96
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3b/5x5"
layer {
type: "Pooling"
top: "inception_3b/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_3b/pool"
top: "inception_3b/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3b/pool_proj"
layer {
type: "Concat"
top: "inception_3b/output"
layer {
type: "Pooling"
bottom: "inception_3b/output"
top: "pool3/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
bottom: "pool3/3x3_s2"
top: "inception_4a/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 192
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4a/1x1"
layer {
type: "Convolution"
top: "inception_4a/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 96
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4a/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4a/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 208
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4a/3x3"
layer {
type: "Convolution"
top: "inception_4a/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4a/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4a/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 48
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4a/5x5"
layer {
type: "Pooling"
top: "inception_4a/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4a/pool"
top: "inception_4a/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4a/pool_proj"
layer {
type: "Concat"
top: "inception_4a/output"
layer {
type: "Convolution"
bottom: "inception_4a/output"
top: "inception_4b/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4b/1x1"
layer {
type: "Convolution"
top: "inception_4b/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 112
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4b/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4b/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 224
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4b/3x3"
layer {
type: "Convolution"
top: "inception_4b/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4b/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4b/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4b/5x5"
layer {
type: "Pooling"
top: "inception_4b/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4b/pool"
top: "inception_4b/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4b/pool_proj"
layer {
type: "Concat"
top: "inception_4b/output"
layer {
type: "Convolution"
bottom: "inception_4b/output"
top: "inception_4c/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4c/1x1"
layer {
type: "Convolution"
top: "inception_4c/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4c/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4c/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4c/3x3"
layer {
type: "Convolution"
top: "inception_4c/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4c/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4c/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4c/5x5"
layer {
type: "Pooling"
top: "inception_4c/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4c/pool"
top: "inception_4c/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4c/pool_proj"
layer {
type: "Concat"
top: "inception_4c/output"
layer {
type: "Convolution"
bottom: "inception_4c/output"
top: "inception_4d/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 112
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4d/1x1"
layer {
type: "Convolution"
top: "inception_4d/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 144
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4d/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4d/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 288
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4d/3x3"
layer {
type: "Convolution"
top: "inception_4d/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4d/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4d/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4d/5x5"
layer {
type: "Pooling"
top: "inception_4d/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4d/pool"
top: "inception_4d/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4d/pool_proj"
layer {
type: "Concat"
top: "inception_4d/output"
layer {
type: "Convolution"
bottom: "inception_4d/output"
top: "inception_4e/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4e/1x1"
layer {
type: "Convolution"
top: "inception_4e/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4e/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4e/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 320
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4e/3x3"
layer {
type: "Convolution"
top: "inception_4e/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4e/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4e/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4e/5x5"
layer {
type: "Pooling"
top: "inception_4e/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4e/pool"
top: "inception_4e/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4e/pool_proj"
layer {
type: "Concat"
top: "inception_4e/output"
layer {
type: "Convolution"
bottom: "inception_4e/output"
top: "inception_5a/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5a/1x1"
layer {
type: "Convolution"
top: "inception_5a/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5a/3x3_reduce"
layer {
type: "Convolution"
top: "inception_5a/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 320
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5a/3x3"
layer {
type: "Convolution"
top: "inception_5a/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5a/5x5_reduce"
layer {
type: "Convolution"
top: "inception_5a/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5a/5x5"
layer {
type: "Pooling"
top: "inception_5a/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_5a/pool"
top: "inception_5a/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5a/pool_proj"
layer {
type: "Concat"
top: "inception_5a/output"
layer {
type: "Convolution"
bottom: "inception_5a/output"
top: "inception_5b/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 384
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5b/1x1"
layer {
type: "Convolution"
top: "inception_5b/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 1
decay_mult: 0
convolution_param {
num_output: 192
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5b/3x3_reduce"
layer {
type: "Convolution"
top: "inception_5b/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 384
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5b/3x3"
layer {
type: "Convolution"
top: "inception_5b/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 48
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5b/5x5_reduce"
layer {
type: "Convolution"
top: "inception_5b/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5b/5x5"
layer {
type: "Pooling"
top: "inception_5b/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_5b/pool"
top: "inception_5b/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5b/pool_proj"
layer {
type: "Concat"
top: "inception_5b/output"
layer {
type: "Dropout"
bottom: "inception_5b/output"
top: "pool5/drop_s1"
dropout_param {
dropout_ratio: 0.4
layer {
type: "Convolution"
bottom: "pool5/drop_s1"
top: "cvg/classifier"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 1
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.
layer {
type: "Sigmoid"
bottom: "cvg/classifier"
top: "coverage"
layer {
type: "Convolution"
top: "bboxes"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 4
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.
# End of convolutional network
# Convert bboxes
layer {
type: "Eltwise"
bottom: "bboxes"
bottom: "coverage-block"
top: "bboxes-masked"
eltwise_param {
operation: PROD
layer {
type: "Eltwise"
bottom: "bboxes-masked"
top: "bboxes-masked-norm"
eltwise_param {
operation: PROD
layer {
type: "Eltwise"
bottom: "bboxes-masked-norm"
bottom: "obj-block"
top: "bboxes-obj-masked-norm"
eltwise_param {
operation: PROD
# Loss layers
layer {
type: "L1Loss"
bottom: "bboxes-obj-masked-norm"
bottom: "bbox-obj-label-norm"
top: "loss_bbox"
loss_weight: 2
layer {
type: "EuclideanLoss"
bottom: "coverage"
bottom: "coverage-label"
top: "loss_coverage"
# Cluster bboxes
layer {
type: 'Python'
bottom: 'coverage'
bottom: 'bboxes'
top: 'bbox-list'
python_param {
module: 'caffe.layers.detectnet.clustering'
layer: 'ClusterDetections'
param_str : '640, 640, 16, 0.6, 2, 0.02, 22, 1'
include: { phase: TEST }
# Calculate mean average precision
layer {
type: 'Python'
bottom: 'coverage-label'
bottom: 'bbox-label'
top: 'bbox-list-label'
python_param {
layer: 'ClusterGroundtruth'
param_str : '640, 640, 16, 1'
layer {
type: 'Python'
bottom: 'bbox-list-label'
bottom: 'bbox-list'
top: 'bbox-list-scored'
python_param {
module: 'caffe.layers.detectnet.mean_ap'
layer: 'ScoreDetections'
layer {
type: 'Python'
bottom: 'bbox-list-scored'
top: 'mAP'
top: 'precision'
top: 'recall'
python_param {
layer: 'mAP'
param_str : '640, 640, 16'
and here is the caffemodel: http://dl.caffe.berkeleyvision.org/bvlc_googlenet.caffemodel
Of course. Here:
# DetectNet network
# Data/Input layers
layer {
type: "Data"
top: "data"
data_param {
backend: LMDB
batch_size: 10
layer {
type: "Data"
top: "label"
data_param {
backend: LMDB
batch_size: 10
layer {
type: "Data"
top: "data"
data_param {
backend: LMDB
batch_size: 6
layer {
type: "Data"
top: "label"
data_param {
backend: LMDB
batch_size: 6
layer {
type: "Input"
top: "data"
input_param {
shape {
dim: 1
dim: 3
dim: 640
dim: 640
layer {
bottom: "data"
bottom: "label"
stride: 16
scale_cvg: 0.4
min_cvg_len: 20
obj_norm: true
image_size_x: 640
image_size_y: 640
crop_bboxes: false
crop_prob: 1
shift_x: 32
shift_y: 32
flip_prob: 0.5
rotation_prob: 0
scale_prob: 0.4
scale_min: 0.8
scale_max: 1.2
hue_rotation: 30
transform_param: {
mean_value: 127
layer {
bottom: "data"
bottom: "label"
stride: 16
scale_cvg: 0.4
min_cvg_len: 20
obj_norm: true
image_size_x: 640
image_size_y: 640
crop_bboxes: false
transform_param: {
mean_value: 127
layer {
type: "Power"
bottom: "data"
power_param {
shift: -127
layer {
type: "Slice"
top: "bbox-label"
top: "size-label"
top: "obj-label"
slice_param {
slice_dim: 1
slice_point: 1
slice_point: 5
slice_point: 7
slice_point: 8
layer {
type: "Concat"
concat_param {
concat_dim: 1
layer {
type: "Concat"
top: "size-block"
concat_param {
concat_dim: 1
layer {
type: "Concat"
bottom: "obj-label"
bottom: "obj-label"
bottom: "obj-label"
bottom: "obj-label"
top: "obj-block"
concat_param {
concat_dim: 1
layer {
type: "Eltwise"
eltwise_param {
operation: PROD
layer {
type: "Eltwise"
bottom: "obj-block"
eltwise_param {
operation: PROD
layer {
type: "Convolution"
top: "conv1/7x7_s2"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 3
kernel_size: 7
stride: 2
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
top: "conv1/7x7_s2"
layer {
type: "Pooling"
top: "pool1/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "LRN"
top: "pool1/norm1"
lrn_param {
local_size: 5
alpha: 0.0001
beta: 0.75
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "conv2/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 192
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "conv2/3x3"
top: "conv2/3x3"
layer {
type: "LRN"
bottom: "conv2/3x3"
top: "conv2/norm2"
lrn_param {
local_size: 5
alpha: 0.0001
beta: 0.75
layer {
type: "Pooling"
top: "pool2/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 96
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 192
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 96
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Pooling"
top: "pool3/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 192
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 96
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 208
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 48
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 112
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 224
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 112
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 144
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 288
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 320
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 320
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 384
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 1
decay_mult: 0
convolution_param {
num_output: 192
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 384
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 48
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Dropout"
dropout_param {
dropout_ratio: 0.4
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 1
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.
layer {
type: "Sigmoid"
top: "coverage"
layer {
type: "Convolution"
top: "bboxes"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 4
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.
# Convert bboxes
layer {
type: "Eltwise"
bottom: "bboxes"
eltwise_param {
operation: PROD
layer {
type: "Eltwise"
eltwise_param {
operation: PROD
layer {
type: "Eltwise"
bottom: "obj-block"
eltwise_param {
operation: PROD
# Loss layers
layer {
type: "L1Loss"
top: "loss_bbox"
loss_weight: 2
layer {
bottom: "coverage"
# Cluster bboxes
layer {
type: 'Python'
bottom: 'coverage'
bottom: 'bboxes'
top: 'bbox-list'
python_param {
layer {
type: 'Python'
python_param {
layer {
type: 'Python'
bottom: 'bbox-list'
python_param {
layer {
type: 'Python'
top: 'mAP'
top: 'precision'
top: 'recall'
python_param {
layer: 'mAP'
Hi doruk8,
your protofile can’t be parsed by our TenrsorRT, could you use following command to make sure protofile can be parsed correct?
nvidia@tegra-ubuntu:~/morgan/wayne/tegra_multimedia_api/data/Model/resnet10-old$ /usr/src/tensorrt/bin/giexec --deploy=customer.prototxt --output=bbox/regressor --half2 --batch=1
deploy: customer.prototxt
output: bbox/regressor
half2
batch: 1
[libprotobuf ERROR google/protobuf/text_format.cc:298] Error parsing text-format ditcaffe.NetParameter: 72:30: Message type “ditcaffe.LayerParameter” has no field named “detectnet_groundtruth_param”.
Could not parse deploy file
Engine could not be created
wayne zhu
Sorry for late reply. I’ve tried the command you mentioned and I got the same result so I’ve changed the model to ped100 model included under jetson-inference repo of dusty-nv and I’ve made a few changes on model then fed your command with it. This is the result I am getting right now:
/usr/src/tensorrt/bin/giexec --deploy=deploy.prototxt --output=bbox/regressor --half2 --batch=1
deploy: deploy.prototxt
half2
batch: 1
Input “data”: 3x512x1024
Output “bbox/regressor”: 4x32x64
name=data, bindingIndex=0, buffers.size()=2
name=bbox/regressor, bindingIndex=1, buffers.size()=2
Average over 10 runs is 52.5085 ms.
Average over 10 runs is 45.6385 ms.
Average over 10 runs is 45.589 ms.
Average over 10 runs is 45.6846 ms.
Average over 10 runs is 45.6238 ms.
Average over 10 runs is 45.6285 ms.
Average over 10 runs is 45.6679 ms.
Average over 10 runs is 45.5692 ms.
Average over 10 runs is 45.566 ms.
Average over 10 runs is 45.5034 ms.
Then I’ve fed this command with the default DeepStream model Resnet-18. Here is the result of default DeepStream model:
/usr/src/tensorrt/bin/giexec --deploy=ResNet_18_threeClass_VGA_deploy_pruned.prototxt --output=Layer11_bbox --half2 --batch=1
deploy: ResNet_18_threeClass_VGA_deploy_pruned.prototxt
output: Layer11_bbox
half2
batch: 1
Input “data”: 3x368x640
Output “Layer11_bbox”: 12x23x40
name=Layer11_bbox, bindingIndex=1, buffers.size()=2
Average over 10 runs is 40.2628 ms.
Average over 10 runs is 14.6118 ms.
Average over 10 runs is 14.7133 ms.
Average over 10 runs is 14.738 ms.
Average over 10 runs is 14.6577 ms.
Average over 10 runs is 14.6635 ms.
Average over 10 runs is 14.7344 ms.
Average over 10 runs is 14.7653 ms.
Average over 10 runs is 14.7213 ms.
Average over 10 runs is 14.6916 ms.
Now when I run DeepStream with the custom model which TensorRT parsed correctly (named as deploy.prototxt), DeepStream generates cache file and opens the camera, displays the live webcam stream but no bounding box. I think some changes should be made in config file you pass to DeepStream but I don’t know how to configure it according to DetectNet ped100 model. I would like to know your ideas about it. Thanks in advance. Here is the deploy.prototxt:
input: "data"
input_shape {
dim: 1
dim: 3
dim: 512
dim: 1024
layer {
type: "Power"
bottom: "data"
power_param {
shift: 0.0
layer {
type: "Convolution"
top: "conv1/7x7_s2"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 3
kernel_size: 7
stride: 2
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
top: "conv1/7x7_s2"
layer {
type: "Pooling"
top: "pool1/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "LRN"
top: "pool1/norm1"
lrn_param {
local_size: 5
alpha: 0.0001
beta: 0.75
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
top: "conv2/3x3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 192
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "conv2/3x3"
top: "conv2/3x3"
layer {
type: "LRN"
bottom: "conv2/3x3"
top: "conv2/norm2"
lrn_param {
local_size: 5
alpha: 0.0001
beta: 0.75
layer {
type: "Pooling"
top: "pool2/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 96
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 16
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 192
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 96
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Pooling"
top: "pool3/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 192
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 96
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 208
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 16
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 48
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 112
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 224
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 24
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 24
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 112
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 144
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 288
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 256
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 320
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 256
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 320
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 384
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 192
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 384
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 48
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Pooling"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
layer {
type: "Concat"
layer {
type: "Dropout"
dropout_param {
dropout_ratio: 0.4
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 1
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.
layer {
type: "Convolution"
top: "bbox/regressor"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 4
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.
Hi doruk898,
Good to know you have succeed to run with your model.
Have you write your parse function for your network?
I mean in config file:
parse-func=4 //it will finally call to a parser function
If you use specific model, you need write this function.
wayne zhu
Yes but there is one problem about that. When I run the gst-inspect-1.0 nvcaffegie command, it gives
parse-func : Detector BBOX parse function type
flags: readable, writable, changeable only in NULL or READY state
Enum “GstNvCaffeDetectorParseFuncType” Default: 1, “Googlenet parse function”
(0): Custom parse function - custom parse
(1): Googlenet parse function - googlenet
(2): Nvidia model type 0 parse function - nv0
(3): Nvidia model type 1 parse function - nv1
(4): Nvidia model resnet parse function - resnet
Since the DetectNet model derivative of GoogleNet, I’m using parse-func=1 in my config file but it throws error. However if I run my config file with parse-func=4, no problem. I think my model works but no bounding box. This is my primary-gie section:
[primary-gie]
enable=1
net-scale-factor=0.0039215697906911373
model-file=file:///home/nvidia/tegra_multimedia_api/data/Model/GoogleNet_one_class/snapshot_iter_70800.caffemodel
proto-file=file:///home/nvidia/tegra_multimedia_api/data/Model/GoogleNet_one_class/deploy.prototxt
#model-cache=file:///home/nvidia/tegra_multimedia_api/data/Model/GoogleNet_one_class/snapshot_iter_70800.caffemodel_b2_fp16.cache
labelfile-path=file:///home/nvidia/Model/ResNet_18/labels.txt
#labelfile-path=file:///home/nvidia/jetson-inference/data/networks/ilsvrc12_synset_words.txt
net-stride=16
batch-size=2
#bbox-bg-color0=0;1;0;0.2
#bbox-bg-color1=0;1;1;0.2
#bbox-bg-color2=0;1;1;0.2
#bbox-bg-color3=1;0;0;0.2
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;1;1;1
bbox-border-color3=0;1;0;1
num-classes=4
class-thresholds=0.2;0.2;0.2;0.2
class-eps=0.1;0.1;0.1;0.1
class-group-thresholds=3;3;3;3
color-format=0
roi-top-offset=0;0
roi-bottom-offset=0;0
detected-min-w=0;0
detected-min-h=0;0
detected-max-w=1920;100;1920;1920
detected-max-h=1080;1080;1080;1080
interval=1
-2 for all; -1 for none;
To set multiple class id’s use format as “1;2;0”
detect-color-class-ids=0;
gie-unique-id=1
parse-func=4
is-classifier=0
output-bbox-name=bbox/regressor
output-blob-names=cvg/classifier
I’m not sure if the problem I’m having is related to labels or need of changes in config file or is my model completely wrong. This is exactly what my problem is. I even used built-in GoogleNet model which included in Tegra Multimedia API, still no result. Do you think it is because of parsing function tensorrt uses?
Could you share your config file with built-in GooglNet model? so I can have a test on my side.
wayne zhu
Hi, I just set parse-func=4 and commented model-cache parameter to reproduce cache file. It crated the cache file for GoogleNet model and now I’m able to see some bounding boxes that produced by GoogleNet model below. However, result is worse than ResNet-18 model which comes with DeepStream SDK as default and very low fps (around 5 fps). Here is the GoogleNet model I’ve tried:
input: "data"
input_dim: 1
input_dim: 3
input_dim: 540
input_dim: 960
layer {
type: "Convolution"
bottom: "data"
top: "conv1/7x7_s2"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 3
kernel_size: 7
stride: 2
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "conv1/7x7_s2"
top: "conv1/7x7_s2"
layer {
type: "Pooling"
top: "pool1/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "LRN"
bottom: "pool1/3x3_s2"
top: "pool1/norm1"
lrn_param {
local_size: 5
alpha: 0.0001
beta: 0.75
layer {
type: "Convolution"
bottom: "pool1/norm1"
top: "conv2/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "conv2/3x3_reduce"
layer {
type: "Convolution"
top: "conv2/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 192
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "conv2/3x3"
top: "conv2/3x3"
layer {
type: "LRN"
bottom: "conv2/3x3"
top: "conv2/norm2"
lrn_param {
local_size: 5
alpha: 0.0001
beta: 0.75
layer {
type: "Pooling"
bottom: "conv2/norm2"
top: "pool2/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
bottom: "pool2/3x3_s2"
top: "inception_3a/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3a/1x1"
layer {
type: "Convolution"
top: "inception_3a/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 96
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3a/3x3_reduce"
layer {
type: "Convolution"
top: "inception_3a/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3a/3x3"
layer {
type: "Convolution"
top: "inception_3a/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3a/5x5_reduce"
layer {
type: "Convolution"
top: "inception_3a/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3a/5x5"
layer {
type: "Pooling"
top: "inception_3a/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_3a/pool"
top: "inception_3a/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3a/pool_proj"
layer {
type: "Concat"
top: "inception_3a/output"
layer {
type: "Convolution"
bottom: "inception_3a/output"
top: "inception_3b/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3b/1x1"
layer {
type: "Convolution"
top: "inception_3b/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3b/3x3_reduce"
layer {
type: "Convolution"
top: "inception_3b/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 192
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3b/3x3"
layer {
type: "Convolution"
top: "inception_3b/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3b/5x5_reduce"
layer {
type: "Convolution"
top: "inception_3b/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 96
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3b/5x5"
layer {
type: "Pooling"
top: "inception_3b/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_3b/pool"
top: "inception_3b/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_3b/pool_proj"
layer {
type: "Concat"
top: "inception_3b/output"
layer {
type: "Pooling"
bottom: "inception_3b/output"
top: "pool3/3x3_s2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
bottom: "pool3/3x3_s2"
top: "inception_4a/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 192
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4a/1x1"
layer {
type: "Convolution"
top: "inception_4a/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 96
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4a/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4a/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 208
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4a/3x3"
layer {
type: "Convolution"
top: "inception_4a/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4a/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4a/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 48
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4a/5x5"
layer {
type: "Pooling"
top: "inception_4a/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4a/pool"
top: "inception_4a/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4a/pool_proj"
layer {
type: "Concat"
top: "inception_4a/output"
layer {
type: "Convolution"
bottom: "inception_4a/output"
top: "inception_4b/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4b/1x1"
layer {
type: "Convolution"
top: "inception_4b/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 112
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4b/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4b/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 224
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4b/3x3"
layer {
type: "Convolution"
top: "inception_4b/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4b/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4b/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4b/5x5"
layer {
type: "Pooling"
top: "inception_4b/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4b/pool"
top: "inception_4b/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4b/pool_proj"
layer {
type: "Concat"
top: "inception_4b/output"
layer {
type: "Convolution"
bottom: "inception_4b/output"
top: "inception_4c/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4c/1x1"
layer {
type: "Convolution"
top: "inception_4c/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4c/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4c/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4c/3x3"
layer {
type: "Convolution"
top: "inception_4c/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4c/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4c/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4c/5x5"
layer {
type: "Pooling"
top: "inception_4c/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4c/pool"
top: "inception_4c/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4c/pool_proj"
layer {
type: "Concat"
top: "inception_4c/output"
layer {
type: "Convolution"
bottom: "inception_4c/output"
top: "inception_4d/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 112
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4d/1x1"
layer {
type: "Convolution"
top: "inception_4d/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 144
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4d/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4d/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 288
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4d/3x3"
layer {
type: "Convolution"
top: "inception_4d/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4d/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4d/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4d/5x5"
layer {
type: "Pooling"
top: "inception_4d/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4d/pool"
top: "inception_4d/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4d/pool_proj"
layer {
type: "Concat"
top: "inception_4d/output"
layer {
type: "Convolution"
bottom: "inception_4d/output"
top: "inception_4e/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4e/1x1"
layer {
type: "Convolution"
top: "inception_4e/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4e/3x3_reduce"
layer {
type: "Convolution"
top: "inception_4e/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 320
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4e/3x3"
layer {
type: "Convolution"
top: "inception_4e/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4e/5x5_reduce"
layer {
type: "Convolution"
top: "inception_4e/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4e/5x5"
layer {
type: "Pooling"
top: "inception_4e/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_4e/pool"
top: "inception_4e/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_4e/pool_proj"
layer {
type: "Concat"
top: "inception_4e/output"
layer {
type: "Convolution"
bottom: "inception_4e/output"
top: "inception_5a/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5a/1x1"
layer {
type: "Convolution"
top: "inception_5a/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.09
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5a/3x3_reduce"
layer {
type: "Convolution"
top: "inception_5a/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 320
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5a/3x3"
layer {
type: "Convolution"
top: "inception_5a/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.2
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5a/5x5_reduce"
layer {
type: "Convolution"
top: "inception_5a/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5a/5x5"
layer {
type: "Pooling"
top: "inception_5a/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_5a/pool"
top: "inception_5a/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5a/pool_proj"
layer {
type: "Concat"
top: "inception_5a/output"
layer {
type: "Convolution"
bottom: "inception_5a/output"
top: "inception_5b/1x1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 384
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5b/1x1"
layer {
type: "Convolution"
top: "inception_5b/3x3_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 1
decay_mult: 0
convolution_param {
num_output: 192
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5b/3x3_reduce"
layer {
type: "Convolution"
top: "inception_5b/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 384
pad: 1
kernel_size: 3
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5b/3x3"
layer {
type: "Convolution"
top: "inception_5b/5x5_reduce"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 48
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5b/5x5_reduce"
layer {
type: "Convolution"
top: "inception_5b/5x5"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5b/5x5"
layer {
type: "Pooling"
top: "inception_5b/pool"
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: "Convolution"
bottom: "inception_5b/pool"
top: "inception_5b/pool_proj"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
type: "ReLU"
bottom: "inception_5b/pool_proj"
layer {
type: "Concat"
top: "inception_5b/output"
layer {
type: "Dropout"
bottom: "inception_5b/output"
top: "pool5/drop_s1"
dropout_param {
dropout_ratio: 0.4
layer {
type: "Convolution"
bottom: "pool5/drop_s1"
top: "cvg/classifier"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.
layer {
type: "Convolution"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: "xavier"
std: 0.03
bias_filler {
type: "constant"
value: 0.
layer {
type: "Deconvolution"
bottom: "cvg/classifier"
top: "cvg/tile"
param {
lr_mult: 0
param {
lr_mult: 0
convolution_param {
num_output: 1
kernel_size: 4
stride: 4
layer {
bottom: "bbox/regressor"
top: "bboxes"
param {
lr_mult: 0
param {
lr_mult: 0
convolution_param {
num_output: 4
kernel_size: 4
stride: 4
layer {
type: "Sigmoid"
bottom: "cvg/tile"
top: "coverage"
and here is my config file:
[application]
enable-perf-measurement=1
roi-marking=1
perf-measurement-interval-sec=5
gie-kitti-output-dir=/home/nvidia/kitti1/
0 = standalone; 1 = server; 2 = client
app-mode=0
[source0]
enable=1
#Type - 1=CameraCSi 2=CameraV4L2 3=URI
type=3
camera-width=1920
camera-height=1080
camera-fps-n=30
camera-fps-d=1
camera-csi-sensor-id=1 # Developer kit onboard kamera için (type=1)
camera-v4l2-dev-node=1 # USB kamera için (type=2)
uri=file:///home/nvidia/sample_720p.mp4
[sink0]
enable=1
#Type - 1=FakeSink 2=OverlaySink 3=EglSink 4=XvImageSink 5=File
type=2
display-id=0
offset-x=0
offset-y=0
width=0
height=0
sync=1
overlay-index=1
source-id=0
[sink1]
enable=0
type=5
#1=mp4 2=mkv
container=2
#1=h264 2=h265
codec=1
bitrate=10000000
#1=cbr 2=vbr
rc-mode=2
iframeinterval=30
#1=baseline 2=main 3=high
profile=3
output-file=out.mp4
source-id=0
[osd]
enable=1
osd-mode=2
border-width=7
text-size=10
text-color=1;2;3;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0;
[primary-gie]
enable=1
model-file=file:///home/nvidia/tegra_multimedia_api/data/Model/GoogleNet_one_class/GoogleNet_modified_oneClass_halfHD.caffemodel
proto-file=file:///home/nvidia/tegra_multimedia_api/data/Model/GoogleNet_one_class/GoogleNet_modified_oneClass_halfHD.prototxt
model-cache=file:///home/nvidia/tegra_multimedia_api/data/Model/GoogleNet_one_class/GoogleNet_modified_oneClass_halfHD.caffemodel_b2_fp16.cache
net-stride=16
batch-size=2
num-classes=4
color-format=0
roi-top-offset=0;0
detected-min-w=0;0
detected-min-h=0;0
interval=1
gie-unique-id=1
parse-func=4
is-classifier=0
Uncomment below lines for DBSCAN. EPS and minBoxes can be tuned for DBSCAN
#enable-dbscan=1
#class-minBoxes=4;4;4;4
#class-eps=0.7;0.7;0.7;0.7
Bit 0: Model decryption required
crypto-flags=0
[secondary-gie4]
enable=1
net-scale-factor=1
model-file=file:///home/nvidia/Model/ivaSecondary_VehicleTypes_V1/snapshot_iter_13740.caffemodel
proto-file=file:///home/nvidia/Model/ivaSecondary_VehicleTypes_V1/deploy.prototxt
model-cache=file:///home/nvidia/Model/ivaSecondary_VehicleTypes_V1/snapshot_iter_13740.caffemodel_b2_fp16.cache
labelfile-path=file:///home/nvidia/Model/ivaSecondary_VehicleTypes_V1/labels.txt
net-stride=16
batch-size=2
num-classes=6
detected-min-w=128
detected-min-h=128
color-format=1
interval=0
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=2;
is-classifier=1
output-blob-names=softmax
offsets=73.00;77.55;88.9
sgie-async-mode=1
sec-class-threshold=0.51
[secondary-gie5]
enable=1
net-scale-factor=1
model-file=file:///home/nvidia/Model/IVA_secondary_carcolor_V1/CarColorPruned.caffemodel
proto-file=file:///home/nvidia/Model/IVA_secondary_carcolor_V1/deploy.prototxt
mean-file=file:///home/nvidia/Model/IVA_secondary_carcolor_V1/mean.ppm
model-cache=file:///home/nvidia/Model/IVA_secondary_carcolor_V1/CarColorPruned.caffemodel_b2_fp16.cache
labelfile-path=file:///home/nvidia/Model/IVA_secondary_carcolor_V1/labels.txt
net-stride=16
batch-size=2
detected-min-w=128
detected-min-h=128
color-format=1
num-classes=12
interval=0
gie-unique-id=5
operate-on-gie-id=1
is-classifier=1
sgie-async-mode=1
[secondary-gie6]
enable=1
net-scale-factor=1
model-file=file:///home/nvidia/Model/IVASecondary_Make_V1/snapshot_iter_6240.caffemodel
proto-file=file:///home/nvidia/Model/IVASecondary_Make_V1/deploy.prototxt
model-cache=file:///home/nvidia/Model/IVASecondary_Make_V1/snapshot_iter_6240.caffemodel_b2_fp16.cache
mean-file=file:///home/nvidia/Model/IVASecondary_Make_V1/mean.ppm
labelfile-path=file:///home/nvidia/Model/IVASecondary_Make_V1/labels.txt
net-stride=16
batch-size=2
num-classes=24
detected-min-w=128
detected-min-h=128
color-format=1
interval=0
gie-unique-id=6
operate-on-gie-id=1
is-classifier=1
sgie-async-mode=1
crypto-flags=0
[tracker]
enable=1
tracker-width=960
tracker-height=540
[tests]
file-loop-count=0
#0=send overlaps; 1=do not send overlaps
server-overlap-mode=1
#Fixed to 1 for diplay color in GUI mode
color-mode=1
On the other hand, I still think that there is some logical error about parse-func because gst-inspect-1.0 nvcaffgie command tells that “(1): Googlenet parse function - googlenet” but if give parse-func=1 in config file for DeepStream, it throws error and if give parse-func=4 no problem. Why is that?
Hi Dorek,
1, Looks your issue is accuracy issue, could you adjust your threshold in config file, then see result again?
2, I think we have release nvparsebbox_sources code, you can check that about parse function.
wayne zhu
Hi Dorek,
Have you tried our suggestions?
Any result can be shared?
Hi kayccc,
I am so sorry to reply too late. I couldn’t check this post because of other jobs I have.
Now I’m trying to build a detection model with SSD + MobileNet because the pre-trained models I have are too big for TX2. After I train the model and get a result I will be trying this model on DeepStream. So you can close this topic now and if I have further questions related to my custom model, I will create another topic. Is that okay?
