Serving MiniMax‑M3 (vision + long‑context) cross‑node on 2× DGX Spark (GB10, sm_121)
TL;DR — I got the community AutoRound‑mixed quant of MiniMax‑M3 (a ~428B‑param, 128‑expert MoE with native Multi‑head Sparse Attention + a CLIP vision tower) serving across two DGX Spark (GB10) boxes with tensor‑parallel = 2 over the 200G ConnectX‑7 fabric, MSA active (not a dense fallback), and working image understanding. The quant author had only ever run it single‑node, text‑only — so the cross‑node + vision parts are new. Below is exactly what it took, including the GB10/sm_121 gotchas that will bite anyone doing MoE on these boxes.
This is a “make it work” report, not a performance brag: it’s eager‑only (~5 tok/s decode) for hardware reasons explained below. The value here is (a) it runs at all on 2× Spark, (b) the sm_121 findings, and (c) the vision‑loader trick.
Hardware / software
  • 2× DGX Spark (GB10) — each 121 GB unified memory, compute capability 12.1 (sm_121). Combined ~242 GB usable, which is what makes a 189 GB model possible at all.
  • Direct‑cabled ConnectX‑7 200G (RoCE); no GPUDirect on GB10, so cross‑node collectives go through host bounce buffers.
  • vLLM 0.23.1rc1.dev with the native MiniMax‑M3 model (incl. MiniMaxM3SparseForConditionalGeneration + the MSA path).
  • Model: aquaman164/MiniMax-M3-AutoRound-3.2bit-longctx (188.6 GB, 36 shards). Plugin: OneCompression ( GitHub - mmzz164/OneCompression: Python package for LLM compression · GitHub , tag m3-serving-v1 — Fujitsu, Apache). Credit to both.
Per‑GPU footprint at TP=2: 88.4 GiB weights/node (incl. the 3.4 GB vision tower). MSA + only 4 KV heads make KV very cheap, so a small KV pool still gives a big context window.
Step 1 — Get the quant to load (config surgery)
  1. Unsupported weight_bits: 16 — AutoRound uses a 16‑bit base with per‑module overrides; vLLM’s stock validator only accepts {2,3,4,8}. Fix: register OneComp’s autoround_mixed method and rename quant_methodautoround_mixed in config.json so the stock validator never fires.
  2. Unsupported activation: silu — bake the missing values into config.json (top‑level and text_config): hidden_act=swigluoai, swiglu_alpha=1.702, swiglu_beta=1.0, swiglu_limit=7.0, rope_theta=5e6, partial_rotary_factor=0.5, rotary_dim=64, head_dim=128, use_gemma_norm=true, use_qk_norm=true, qk_norm_type=per_head, dense_intermediate_size=12288, shared_intermediate_size=3072, n_shared_experts=1, scoring_func=sigmoid, use_routing_bias=true, routed_scaling_factor=2.0. n_shared_experts=1 is critical — without it the shared expert is dropped in every MoE layer → garbage.
Load the plugin into vllm serve via a tiny vllm.general_plugins entry‑point shim (no fork; not pip‑installed, just on sys.path).
Step 2 — Cross‑node engine args (GB10 specifics)
--tensor-parallel-size 2 --enable-expert-parallel
--quantization autoround_mixed --trust-remote-code
--block-size 128 # MANDATORY for MSA
--attention-backend TRITON_ATTN # FLASHINFER incompatible with MSA's block_size=128
--enforce-eager # MoE cudagraph wall, see Step 3
--disable-custom-all-reduce # custom all-reduce unreliable on sm_121
--dtype bfloat16 --gpu-memory-utilization 0.85 --max-model-len 40960
Use a no‑ray multi‑node launcher — Ray’s cross‑node NCCL hangs on GB10.
Step 3 — The sm_121 wall: MoE cannot use CUDA graphs
Any cudagraph mode (incl. PIECEWISE) dies with CUDA error: illegal memory access during capture for this 128‑expert MoE. Confirmed three ways (author on sm_120, me on sm_121, and the known GB10 result: “CUDA graph capture fails for MoE dispatch patterns on sm_121 → use --enforce-eager; dense models can use cudagraphs, large MoE cannot.”). Eager is mandatory for MoE on GB10. That + per‑layer cross‑node all‑reduce over RoCE (no GPUDirect) is why decode is ~5 tok/s — structural, not the quant.
Step 4 — Vision (the part that wasn’t supposed to work)
Switch to MiniMaxM3SparseForConditionalGeneration + a custom loader. Three keys:
  1. The checkpoint ships vision in BOTH namingsmodel.vision_tower.* (transformers) and vision_tower.vision_model.* (vLLM‑native), 515 tensors each. Skip the transformers copy, pass the vLLM‑named copy straight through the model’s own hf_to_vllm_mapper — vision loads almost free.
  2. Language still needs translation + de‑quant: model.language_model.X → language_model.model.X' (experts gate/up/down→w1/w3/w2, indexer→index_, mlp.*→block_sparse_moe.*); de‑quant the fused q/k/v (fuse with a bf16 MSA indexer) and split the pre‑fused gate_up.
  3. Don’t drop lm_head — it’s a bare top‑level lm_head.weight that must map to language_model.lm_head.weight, else silent garbage logits.
Vision tower is only 3.37 GB — fits in budget. Gotcha: the first image request triggers a one‑time ~20 s flashinfer/FlashAttention ViT JIT autotune (AttentionBackendEnum.FLASH_ATTN for vit attention); use a long client timeout or a warmup image, then it’s fast.
Result
Cross‑node, TP=2, MSA active, vision working. Text: coherent with <mm:think> reasoning (“Paris”/“東京”). Vision: fed a synthetic image (red circle, blue square, green triangle, caption “M3 VISION TEST”) → M3 listed every shape, color, position, the inverted triangle, and read the text. Footprint 88.4 GiB/node, 40k context. Throughput ~5 tok/s decode / ~74 tok/s prefill — a long‑context/multimodal endpoint, not a speed daemon.
Gotcha checklist
  • not doneRename quant_method → autoround_mixed (else weight_bits: 16 reject)
  • not doneFORCE config in both top level and text_config (esp. swigluoai, n_shared_experts=1)
  • not done--block-size 128 + --attention-backend TRITON_ATTN
  • not done--enforce-eager (MoE cudagraph crashes on sm_121)
  • not done--disable-custom-all-reduce
  • not doneVision: ForConditionalGeneration arch, keep vLLM‑named vision weights, fix bare lm_head, >150 s timeout on first image
I have it running with 12tk/s but without vision as I needed to test quality of 3.2 bit quant first… not sure what can be done to get more out of this quant or model on 2x Sparks
wow thats slow im running qwen 3.5 397b without MTP enabled since MTP will make me OOM if I have vision enabled and have a steady 29.2tk/s decode and 3800tk/s pp speed minimax really needs to help VLLM and llama cpp to properly implement the changes needed to make it usable or it will not get much traction
Rather vllm need to get their ■■■■ together and implement variable quantization. I am learning more and testing antirez dwarfstar on Mac (first test of ds4f was on a single spark using ds), it’s insane what this genius behind redis did alone with Ai help in few months. Vllm should be learning from him. Similarly I am awed that guy’s like Jang from omlx/osaurus did for Mac community, it just works and works well, insane new variable quantization, support of new models comes faster than for cuda. The whole spark project is being held together by guys like eugr, Aiden, miaai, Tony. No support from nvidia, very little or no interest from vllm. They are busy selling sm90 stuff to corps.
I think Jang is posting around here, he got a duo Spark / gave in to the dark forces ;)
Now its good news! Antirez is also doing spark work, not just Mac. We need Redis hero on our side!
I submitted the cuda graph/MoE issue to vLLM and it’s getting attention and some traction from the devs, no fix yet but I was just pleased they were looking at it.
