set constant memory for use in _global function
Suppose I have a C`host main function driver, and I want to set a constant variable on the device which will execute a global device CU function, is there any way to assign a constant variable on the device?
How would the variable be declared?
I can see how to do it with a CU main function, but not with a main C function driver.
Thanks,
Not sure if I understand that correctly, but you can call any CUDA API function outside a .cu file.
So cudaMemcpyToSymbol is your friend.
Peter
