Set stack size limit not working
I’ve been testing some recursive methods and I’m having a difficult time trying to increase the stack size. I just have 3 functions
__device__ void rec1(list_t p1, list_t* p2, int depth, cell_t p3, cell_t p4) {
    printf("depth %d\n", depth);
    if (depth == MAX_DEPTH)
        return;
    else
        rec2(p1, p2, depth + 1, p3, p4);
__device__ void rec2(list_t p1, list_t* p2, int depth, cell_t p3, cell_t p4) {
        return;
    else
        rec1(p1, p2, depth + 1, p3, p4);
__global__ void kernel() {
    list_t p1;
    list_t* p2;
    int depth = 0;
    cell_t p3;
    cell_t p4;
    rec1(p1, p2, depth, p3, p4);
and in my main method I try increasing the stack size
int main() {
    cudaError_t error;
    error = cudaDeviceSetLimit(cudaLimitStackSize, 256 * 1024);
    if (error != cudaSuccess) {
        printf("cudaDeviceSetLimit failed with %d, line(%d)\n", error, __LINE__);
        exit(EXIT_FAILURE);
    size_t p_val;
    error = cudaDeviceGetLimit(&p_val, cudaLimitStackSize);
        printf("cudaDeviceGetLimit failed with %d, line(%d)\n", error, __LINE__);
        exit(EXIT_FAILURE);
    printf("stack size limit: %d\n", p_val);
    //dim3 block_dim(N, M, 1);
    dim3 block_dim(1, 1, 1);
    dim3 grid_dim(1, 1, 1);
    kernel<<<grid_dim, block_dim>>>();
the structures are just placeholders from my actual code
typedef struct generic_list {
    void* list;
    int size;
} list_t;
typedef struct cell {
    int x;
    int y;
} cell_t;
typedef struct cell_level {
    cell_t cell;
    int level;
} cell_level_t;
I have MAX_DEPTH set to 15 right now and it only makes it to a depth of 12 (at which point I get a StackOverflow) regardless of what I set the stack size to. The default stack size is 1024 B.
Anyone have any idea why changing the stack size doesn’t seem to affect the depth of the recursion? I’m running this on Windows 8 in Visual Studio 2013. Maybe there are some compiler settings I have to change?
