Setting up Mellanox NVMf offload
Here is my configuration (for both target and client):
OS: CentOS 7.4
Kernel: 4.14.93
Adapter: Connect-X 5
MOFED: 4.5-1.0.1.0 (installed with nvmf support)
I followed the exact steps listed in this article.
Setting up the offloaded subsystem works fine:
dmesg | grep “enabling port” shows the following output:
[ 80.840122] nvmet_rdma: enabling port 1 (10.3.1.66:4420)
However, trying to connect from the client fails with this message:
nvme connect -t rdma -n nvmf_ss -a 10.3.1.66 -s 4420
Failed to write to /dev/nvme-fabrics: Input/output error
On the target, I see the following messages in dmesg:
[ 80.818518] nvmet: adding nsid 1 to subsystem nvmf_ss
[ 1092.516129] nvmet: creating controller 1 for subsystem nqn.2014-08.org.nvmexpress.discovery for NQN 2014-08.org.nvmexpress:uuid:0e455f8f-65cd-4822-9304-2768a722e81b.
[ 1092.550328] nvmet: creating controller 2 for subsystem nvmf_ss for NQN 2014-08.org.nvmexpress:uuid:0e455f8f-65cd-4822-9304-2768a722e81b.
[ 1092.579202] nvmet_rdma: using dynamic staging buffer ffff9b91b5ab7c00
[ 1092.736825] nvmet_rdma: received IB QP event: last WQE reached (16)
[ 1229.611790] INFO: task kworker/3:2:375 blocked for more than 120 seconds.
[ 1229.625404] Tainted: G OE 4.14.93 #1
[ 1229.635680] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 1229.651418] kworker/3:2 D 0 375 2 0x80000000
[ 1229.662450] Workqueue: ib_cm cm_work_handler [ib_cm]
[ 1229.672376] Call Trace:
[ 1229.677320] ? __schedule+0x22f/0x810
[ 1229.684680] schedule+0x28/0x80
[ 1229.691007] schedule_timeout+0x26e/0x350
[ 1229.699036] wait_for_completion+0xfb/0x160
[ 1229.707445] ? wake_up_q+0x70/0x70
[ 1229.714279] flush_workqueue+0x13d/0x430
[ 1229.722143] ? nvmet_rdma_cm_reject+0x70/0x70 [nvmet_rdma]
[ 1229.733162] nvmet_rdma_queue_connect+0x634/0x9e0 [nvmet_rdma]
[ 1229.744868] ? cma_acquire_dev+0x10a/0x230 [rdma_cm]
[ 1229.754831] ? cma_req_handler+0x19d/0x880 [rdma_cm]
[ 1229.764812] cma_req_handler+0x31f/0x880 [rdma_cm]
[ 1229.774471] cm_process_work+0x22/0x130 [ib_cm]
[ 1229.783562] ? cm_get_bth_pkey.isra.67+0x36/0x90 [ib_cm]
[ 1229.794261] cm_req_handler+0x92e/0xe80 [ib_cm]
[ 1229.803367] ? __switch_to_asm+0x24/0x60
[ 1229.811248] ? __switch_to_asm+0x30/0x60
[ 1229.819116] cm_work_handler+0x113/0x13a9 [ib_cm]
[ 1229.828547] ? __switch_to_asm+0x30/0x60
[ 1229.836446] ? __switch_to_asm+0x24/0x60
[ 1229.844297] process_one_work+0x18a/0x3a0
[ 1229.852369] worker_thread+0x2e/0x390
[ 1229.859716] ? pwq_unbound_release_workfn+0xd0/0xd0
[ 1229.869509] kthread+0x119/0x130
[ 1229.876008] ? __kthread_parkme+0xa0/0xa0
[ 1229.884676] ret_from_fork+0x35/0x40
[ 1229.892389] INFO: task kworker/3:0:3055 blocked for more than 120 seconds.
Any idea what the problem could be?
Hello Shashank,
Many thanks for posting your question on the Mellanox Community. Our apologies for the late reply.
Give me some time to do a test in our lab. We will update you as soon as we have more information.
In the meantime, were you able to test with a more recent version of Mellanox OFED and an update f/w for the ConnectX-5?
Many thanks,
~Mellanox Technical Support.
Hello Shashank,
Hope you are doing well. I was able to test on our lab setup with NVME target device, and I was not able to reproduce the issue. I had no issues connecting from the client to the target.
I follow the same document as you did → https://community.mellanox.com/s/article/howto-configure-nvme-over-fabrics–nvme-of–target-offload
As by now, we have MLNX_OFED 4.7 GA releases, I tested with that version, but I used the same OS version and kernel version you used.
One note though: Based on a known issue from our MLNX_OFED 4.2 drivers, I updated the kmod package as recommended from our RN → https://docs.mellanox.com/display/MLNXOFEDv471001/Known+Issues , Internal Ref. 1263043
My setup:
OS: CentOS Linux release 7.4.1708 (Core)
Kernel: 4.14.9-1.el7.elrepo.x86_64
Driver: MLNX_OFED_LINUX-4.7-1.0.0.1 (Installed with the following options “–add-kernel-support --with-nvmf”)
Target:
modprobe -v nvme num_p2p_queues=1
modprobe -v nvmet
modprobe -v nvmet-rdma
mkdir /sys/kernel/config/nvmet/subsystems/testsubsystem
echo 1 > /sys/kernel/config/nvmet/subsystems/testsubsystem/attr_allow_any_host
echo 1 > /sys/kernel/config/nvmet/subsystems/testsubsystem/attr_offload
mkdir /sys/kernel/config/nvmet/subsystems/testsubsystem/namespaces/1
echo -n /dev/nvme0n1 > /sys/kernel/config/nvmet/subsystems/testsubsystem/namespaces/1/device_path
echo 1 > /sys/kernel/config/nvmet/subsystems/testsubsystem/namespaces/1/enable
mkdir /sys/kernel/config/nvmet/ports/1
echo 4420 > /sys/kernel/config/nvmet/ports/1/addr_trsvcid
echo 192.168.1.121 > /sys/kernel/config/nvmet/ports/1/addr_traddr
echo “rdma” > /sys/kernel/config/nvmet/ports/1/addr_trtype
echo “ipv4” > /sys/kernel/config/nvmet/ports/1/addr_adrfam
ln -s /sys/kernel/config/nvmet/subsystems/testsubsystem/ /sys/kernel/config/nvmet/ports/1/subsystems/testsubsystem
Client:
modprobe -v nvme
modprobe -v nvme-rdma
nvme discover -t rdma -a 192.168.1.121 -s 4420
nvme connect -t rdma -a 192.168.1.121 -s 4420
nvme connect -t rdma -n testsubsystem -a 192.168.1.121 -s 4420
nvme list
Output from Client:
modprobe -v nvme
insmod /lib/modules/4.14.9-1.el7.elrepo.x86_64/extra/mlnx-nvme/host/nvme-core.ko
insmod /lib/modules/4.14.9-1.el7.elrepo.x86_64/extra/mlnx-nvme/host/nvme.ko
insmod /lib/modules/4.14.9-1.el7.elrepo.x86_64/extra/mlnx-nvme/host/nvme-fabrics.ko
insmod /lib/modules/4.14.9-1.el7.elrepo.x86_64/extra/mlnx-nvme/host/nvme-rdma.ko
Discovery Log Number of Records 1, Generation counter 2
=====Discovery Log Entry 0======
trtype: rdma
adrfam: ipv4
subtype: nvme subsystem
treq: not specified, sq flow control disable supported
portid: 1
trsvcid: 4420
subnqn: testsubsystem
traddr: 192.168.1.121
rdma_prtype: not specified
rdma_qptype: connected
rdma_cms: rdma-cm
rdma_pkey: 0x0000
nvme list
Node SN Model Namespace Usage Format FW Rev
/dev/nvme0n1 2d4b9c8b901fe7a3 Linux 1 400.09 GB / 400.09 GB 512 B + 0 B 4.14.9-1
Dmesg output on Target:
[Tue Oct 8 16:56:20 2019] nvme nvme0: pci function 0000:03:00.0
[Tue Oct 8 16:56:22 2019] nvme0n1:
[Tue Oct 8 16:56:51 2019] nvmet: adding nsid 1 to subsystem testsubsystem
[Tue Oct 8 16:57:25 2019] nvmet_rdma: enabling port 1 (192.168.1.121:4420)
[Tue Oct 8 17:01:13 2019] nvmet: creating controller 1 for subsystem nqn.2014-08.org.nvmexpress.discovery for NQN nqn.2014-08.org.nvmexpress:uuid:e996fc57-622d-4237-8c6e-010cd4f6b5e2.
[Tue Oct 8 17:01:50 2019] nvmet: creating controller 1 for subsystem testsubsystem for NQN nqn.2014-08.org.nvmexpress:uuid:e996fc57-622d-4237-8c6e-010cd4f6b5e2.
[Tue Oct 8 17:01:50 2019] nvmet_rdma: using dynamic staging buffer ffff88103e55fe00
[Wed Oct 9 16:16:34 2019] nvmet_rdma: received IB QP event: last WQE reached (16)
If you still are experiencing an issue based on the provided instructions and steps, please do not hesitate to open a Mellanox Support ticket through support@mellanox.com
Many thanks,
After working with Mellanox Support team. we were able to solve the problem.
The problem was that we did not set num_p2p_queues to 1 and we had enabled IOMMU.
For some reason NVMf offloading does not work when IOMMU is enabled.
Hi Team,
Is it possible to test same in MCX75310AAC-NEAT Adaptar Card?
