shared memory alignment
Dear All,
I am dynamically allocating shared memory as shown in the code. From the programming guide, arrays has to be aligned. I tried this code but get the following error:
error: expression must have integral or enum type
[codebox]#define ALIGN(ADDRESS, OFFSET) (((ADDRESS) + (OFFSET) - 1) & (~((OFFSET) - 1)))
extern shared char array;
global void decoderKernel( …) {
char syndrome_buffer = (char) ALIGN(array, sizeof(char));
float soft_output = (float) ALIGN(&syndrome_buffer[n], sizeof(float));
}[/codebox]
Shared memory must reside within the kernel.
