Shared memory How to give it to a __device__ function
Hy,
I’m sorry about my bad english, I’m french.
I have a problem with shared memory. I want to give to a device function an array allocate in shared memory but I don’t know how to do it.
I make something like that :
__device__ void myDeviceFunction(float sdata[], int tid)
		sdata[tid] = tid;
__global__ void myGlobalFunction(float *d_data)
		__shared__ float sdata[];
		int globalId = threadIdx.x + blockIdx.x * blockDim.x;
		sadata[threadIdx.x] = 0;
		myDeviceFunction(sdata, threadIdx.x);
		d_data[globalId] = sdata[threadIdx.x];
void myHostFunction()
	  float *d_data;
	  dim3 blockSize(256);
	  dim3 gridSize(512);
	  int smem = 256 * sizeof(float);
	  cudaMalloc( (void **)&d_data, 256 * 512 * sizeof(float) );
	  myGlobalFunction<<< gridSize, blockSize, smem >>>(d_data);
		 cudaFree( d_data );
but sdata still contains 0 after the launch of myDeviceFunction.
I hope I’m clear.
Thanks for your help.
It works just fine, try this code:
[codebox]
#include <stdio.h>
device void myDeviceFunction(int sdata, int tid) {
sdata[tid] = tid;
global void myGlobalFunction(int *d_data) {
extern __shared__ int sdata[];
sdata[threadIdx.x] = 0;
int main(int argc, char** argv) {
int *d_data;
int *h_data;
int smem = 256*sizeof(int);
cudaMalloc( (void **)&d_data, 256 * sizeof(int) );
cudaMallocHost( (void **)&h_data, 256 * sizeof(int) );
myGlobalFunction<<< 1, 256, smem >>>(d_data);
cudaMemcpy(h_data,d_data,256 * sizeof(int), cudaMemcpyDeviceToHost);
for (unsigned int i=0;i< 256;++i)
	fprintf(stderr,"%3d: %3d\n",i,h_data[i]);
cudaFree( d_data );
cudaFreeHost(h_data);
return 0;
[/codebox]
N.
Yes it works…
