Shared memory
I am work with GTS450 and according spec, I have 1024thread / block and 48KB shared memory / block.
My question is, If some kernel works with 512thread / block, what is maximum shared memory per block? Its 24KB. My problem is that my kernel use 48KB(512thread/block) and it doesnt work well, but there is no error or compiler message.
thx for all answer.
What do you mean by ‘doesnt work well’ exactly?
You can use all the shared memory per SM for one block. Check out the CUDA GPU Occupancy Calculator.
Sorry, I aplologize, I found bug and thx for tip with “CUDA GPU Occupancy Calculator”, its very usefull :-)
