Sharing cuda memory between containers x86 and jetson
In my company we deploy our software in a very decoupled manner based on several docker containers communicating. A part of the workflow involves video decoding, video resizing and inference with a triton server.
Looks like a perfect use case for using deepstream but we actually need a service to manage frames from the decoding to the inference. So far we simply use shared memory which of course creates a big overhead because of all the copies done.
We need something that would answer these demands:
  • should be gpu shared memory
  • one writer, several readers
  • scalable for video streams (up to 60 fps)
  • should be able to be read by different containers
  • should work on gpu servers and jetsons
  • bonus, deepstream could actually directly write the frames into it
What would be the best approach ?
So far the information I have gathered are:
  • nvIPC is not available on jetson
  • nvsci could be a solution ?
  • using cuMemExportToShareableHandle and cuMemImportFromShareableHandle ?
But honestly the lack of examples of usage of the two last propositions are making them really hard to grasp.
Thanks in advance!
If you need to share GPU memory with two processes, please give nvsci a try.
But we don’t have an available example for nvsci+inference.
Maybe another possible alternative is to share the streaming video via RTSP.
If this works for you, we already have some Deepstream samples for this use case:
