I have some problem writing cuda application…
So I need help!
I have some utility function made by me on a .h and .c file and I want to make visible to Host and Device.
How can I do this?
I must use the global keyword before any function? :wacko:
Any help will be very appreciated.
Thanks you
you can declare functions as device host function(…) which will make them compile for both the host cpu and the gpu.
I don’t know if this is what you’re after but:
__device__ __host__ float myFunction(int idx, float data[])
//your computations
//write in C, the subset supported by both CPU and GPU
//so no device only stuff like threadIdx
//and no host only stuff like printf
return someFloat; //example
void CPUcompute(float host_data[], int size)
for(int i=0, i<size, ++i)
myFunction(i, host_data);
__global__ GPUcompute(float device_data[], int size)
int tid = threadIdx.x + blockIdx.x * blockDim.x;
if(tid < size)
myFunction(i, device_data);
You can’t have the kernel compiled as a host function but you can use utility functions compiled to both host and device if you precede the definition by device host
ok I understand finally!
many thanks!!! :)
