I’m going to do some dual gpu processing, if possible.
So I started out with the simpleMultiGPU exsample in the SDK. and tested with both one and 2 cards
CUDA-capable device count: 1
main(): generating input data…
main(): waiting for GPU results…
GPU Processing time: 75.172005 (ms)
Checking the results…
CPU Processing time: 171.246002 (ms)
GPU sum: 16779778.000000; CPU sum: 16779776.312309
Relative difference: 1.005789E-007
CUDA-capable device count: 2
GPU Processing time: 155.711899 (ms)
GPU sum: 16779776.000000; CPU sum: 16779776.312309
So… it’s actually slower on 2 cards…
The sum is more similar to the CPU on 2 cards, but it is more than twice as slow as just on one card.
Can anyone else confirm that this is true… and maybe explain why…
something about used on transfering the data, or…
I’m using the 2 cards on a P35 Motherbord… ie. Not a SLI motherbord.
I’m using the new beta drivers…
KingGuru
