We observed that using deepstream SDK needs additional packages to be downloaded. What will be additional disk and RAM usage of installing/running the deepstream SDK.
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only)
Hardware Platform: Jetson Nano v2
DeepStream Version: 5.0
Jetpack version: Pls specify how to check it ? I flashed downloaded SD image
TensorRT Version: Pls specify how to check it ?
NVIDIA GPU Driver Version: Pls specify how to check it ?
Since you run on Jetson device, then NVIDIA GPU Driver Version will not need.
after a full installation using Jetpack, did some change on this device, that’s a rough data, for your reference.
nvidia@nano-emmc:~$ df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/mmcblk0p1 14384136 11667268 1966484 86% /
and about running ram usage, that would be depending on many, like your model, streams numbers, tracker, etc.
