when using large arrays with fixed size, the GLSL compiler will hang on glLinkProgram.
layout(binding = 0) restrict buffer Buf {
uint array;
works fine, but for example
uint array[1 << 26];
will compile for ages (I’m not sure if it compiles at all as i never witnessed it finishing)
Is this expected behaviour? The reason I want to use fixed size arrays is that I want to place multiple large arrays in one large buffer. While this still is possible using unsized arrays and layout(offset = ???) declarations per array, it is highly inconvenient. What is the best way to
manage several large arrays in SSBO?
