Small error in matrixmul_drv/matrixmul_drv.cpp? Just an error report
I just tried to compile the CUDA SDK samples and
[font=“Courier”]matrixmul_drv/matrixmul_drv.cpp[/font]
refused to compile. The error message was (using gcc version 4.1.2):
[font=“Courier”]matrixmul_drv.cpp: In function ‘CUresult initCUDA(char*, CUfunc_st**)’:
matrixmul_drv.cpp:207: error: jump to label ‘Error’
matrixmul_drv.cpp:191: error: from here
matrixmul_drv.cpp:193: error: crosses initialization of ‘char* module_path’
matrixmul_drv.cpp:187: error: from here
matrixmul_drv.cpp:184: error: from here
matrixmul_drv.cpp:193: error: crosses initialization of ‘char* module_path’[/font]
I took a look at the function and there seems to be a small error (I never used goto’s so I am not sure if this really is an error). I think [font=“Courier”]char* module_path[/font] should be defined before the first goto or the code after the error label can not be compiled/executed since it uses [font=“Courier”]module_path[/font]. :)
-Jens
BTW: Except that problem everything is working as expected even on an unsupported Ubuntu system. :)
I believe that this is an Ubuntu specific bug, as I cannot reproduce it under the supported RHEL-4.3-x86 environment.
Support for additional Linux distributions will be added at a future date.
Thanks,
Lonni
Did you look at the source code?
This is from matrixmul_drv.cpp (I highlighted the problematic parts)
[font=“Courier”]static CUresult
initCUDA(char* executablePath, CUfunction *pMatrixMul )
CUfunction cuFunction = 0;
cuDevice = 0;
CUresult status = cuInit();
if ( CUDA_SUCCESS != status )
goto Error;
char* module_path = cutFindFilePath(“matrixmul_kernel.cubin”, executablePath);
Error:
cuCtxDetach( );
free(module_path);
return status;
}[/font]
If the first branch is taken than module_path has not been defined … how can free be called? :blink:
I know this more C question than directly related to cuda and therefor may be considered off-topic … but I am curious anyway. :D
Hi Jensman,
Yes, this is indeed a bug in the sample code. We’ll have a fix in the next release. For now, you can easily fix it in your local copy:
If ( bug) goto Error;
char *p = new char[256]; // this line generates compile error
Error:
char *p;
If ( bug ) goto Error;
p = new char[256];	// no more compile error
Error:
Mark
