Substrate design | Is the current limit per BGA ball (one terminal) defined ? If so, how to calculate the current limit ? (use ball diameter and its land diameter ?) |
How to decide the line width on the substrate and the required number/size of vias in relation to current ? (Generally required line width is 1mm/1A on PCB. We’d like to know the case of substrate.) |
