Hello everyone, I want to make a question about the efficience of an algorithm that I implemented in the Jetson TK1 board. I’m very newbie in this so please be nice with me :).
I have a grey image that i divided in blocks . Inside of this blocks I must find the maximum value. I must do that extremely fast so I created one GPU block per block in the image in wich I need to find the maximum value and one thread per block in the GPU. My kernel is this.
__global__ void Max(uchar image[],uchar result[],int width,int side)
int col = blockIdx.x*blockDim.x+threadIdx.x;
int rows = blockIdx.y*blockDim.y+threadIdx.y;
int index = col + rows*width;
int max=0;
if(threadIdx.x==0 and threadIdx.y==0)
for(int i=rows;i<rows+side;i++)
for(int j=col+i*width;j<col+(i*width)+side;j++)
if(image[j]>max)
max=image[j];
index=j;
result[index]=0;
else
result[index]=image[index];
I declare the blocks and the threads
dim3 block(32,32);
dim3 thread(32,32);
I copy the image to the GPU and the result matrix
And I call the kernel in this way
Max<<<block,thread>>>(cuda_image,cuda_result,1024,32);
The code works but really I don’t know if I am doing well . I guess that my solution is slow and I think that I’m doing something wrong but I don’t know what.
Do I doing well?
