Solved - running gpt oss 120b with two sparks
Thought I share this with the community and for those still struggling to run gpt oss 120b.
When using @eugr community build, however, the recipe does not work as is, cause there are issues with the latest vllm releases.
To run it correctly (though not optimally), you can use the recipe below. There are a couple of config changes only, the VLLM environment and the mxfp4 layer, which were causing me issues. With this you can also use the no-ray option that stops your cpu spinning at 100%
./run-recipe.sh openai-gpt-oss-120b --no-ray
# Recipe: OpenAI GPT-OSS 120B
# OpenAI's open source 120B MoE model with MXFP4 quantization support
recipe_version: "1"
name: OpenAI GPT-OSS 120B
description: vLLM serving openai/gpt-oss-120b with MXFP4 quantization and FlashInfer
# HuggingFace model to download (optional, for --download-model)
model: openai/gpt-oss-120b
# Container image to use
container: vllm-node-mxfp4
# Build arguments for build-and-copy.sh
build_args:
  - '--exp-mxfp4'
# No mods required for this model
mods: []
# Default settings (can be overridden via CLI)
defaults:
  port: 3000
  host: 0.0.0.0
  tensor_parallel: 2
  gpu_memory_utilization: 0.70
  max_num_batched_tokens: 8192
# Environment variables to set in the container
# VLLM_USE_FLASHINFER_MOE_MXFP4_MXFP8: "1"
env:
  VLLM_MXFP4_BACKEND: TRTLLM_MXFP
# The vLLM serve command template
# Uses MXFP4 quantization for memory efficiency
command: |
  vllm serve openai/gpt-oss-120b \
      --tool-call-parser openai \
      --reasoning-parser openai_gptoss \
      --enable-auto-tool-choice \
      --tensor-parallel-size {tensor_parallel} \
      --distributed-executor-backend ray \
      --gpu-memory-utilization {gpu_memory_utilization} \
      --enable-prefix-caching \
      --load-format fastsafetensors \
      --quantization mxfp4 \
      --mxfp4-backend cutlass \
      --attention-backend FLASHINFER \
      --kv-cache-dtype fp8 \
      --max-num-batched-tokens {max_num_batched_tokens} \
      --host {host} \
      --port {port}
# --mxfp4-layers moe,qkv,o,lm_head \
Thanks for the tutorial, moving to GB10 projects
