[solved] Why can't I compute primes past 85 million? (sieve of eratosthenes)
Why can’t I compute primes past 85 million?
85 million bytes represents roughly 0.8 GB. I have a GTX 780 (3 GB), so shouldn’t my code be able to compute at least primes up to 2 billion or 3 billion?
With my current code, I’m hitting a wall and not being able to compute prime numbers past 85 million.
If I try to do so, my system freezes when I run the program, and a few seconds later, it gets unfrozen, with a crashed program. Error message:
CUDA error at prime.cu:129 code=6(cudaErrorLaunchTimeout) "cudaDeviceSynchronize()"
This is my code, prime.cu:
#include <stdio.h>
#include <helper_cuda.h> // checkCudaErrors() - NVIDIA_CUDA-6.0_Samples/common/inc
// #include <cuda.h>
// #include <cuda_runtime_api.h>
// #include <cuda_runtime.h>
typedef unsigned long long int uint64_t;
* kernel that initializes the 1st couple of values in the primes array.
__global__ static void sieveInitCUDA(char* primes)
   primes[0] = 1; // value of 1 means the number is NOT prime
   primes[1] = 1; // numbers "0" and "1" are not prime numbers
* kernel for sieving the even numbers starting at 4.
__global__ static void sieveEvenNumbersCUDA(char* primes, uint64_t max)
   uint64_t index = blockIdx.x * blockDim.x + threadIdx.x + threadIdx.x + 4;
   if (index < max)
      primes[index] = 1;
* kernel for finding prime numbers using the sieve of eratosthenes
* - primes: an array of bools. initially all numbers are set to "0".
*           A "0" value means that the number at that index is prime.
* - max: the max size of the primes array
* - maxRoot: the sqrt of max (the other input). we don't wanna make all threads
*   compute this over and over again, so it's being passed in
__global__ static void sieveOfEratosthenesCUDA(char *primes, uint64_t max,
                                               const uint64_t maxRoot)
   // get the starting index, sieve only odds starting at 3
   // 3,5,7,9,11,13...
   /* int index = blockIdx.x * blockDim.x + threadIdx.x + threadIdx.x + 3; */
   // apparently the following indexing usage is faster than the one above. Hmm
   int index = blockIdx.x * blockDim.x + threadIdx.x + 3;
   // make sure index won't go out of bounds, also don't start the execution
   // on numbers that are already composite
   if (index < maxRoot && primes[index] == 0)
      // mark off the composite numbers
      for (int j = index * index; j < max; j += index)
         primes[j] = 1;
* checkDevice()
__host__ int checkDevice()
   // query the Device and decide on the block size
   int devID = 0; // the default device ID
   cudaError_t error;
   cudaDeviceProp deviceProp;
   error = cudaGetDevice(&devID);
   if (error != cudaSuccess)
      printf("CUDA Device not ready or not supported\n");
      printf("%s: cudaGetDevice returned error code %d, line(%d)\n", __FILE__, error, __LINE__);
      exit(EXIT_FAILURE);
   error = cudaGetDeviceProperties(&deviceProp, devID);
   if (deviceProp.computeMode == cudaComputeModeProhibited || error != cudaSuccess)
      printf("CUDA device ComputeMode is prohibited or failed to getDeviceProperties\n");
      return EXIT_FAILURE;
   // Use a larger block size for Fermi and above (see compute capability)
   return (deviceProp.major < 2) ? 16 : 32;
* genPrimesOnDevice
* - inputs: limit - the largest prime that should be computed
*           primes - an array of size [limit], initialized to 0
__host__ void genPrimesOnDevice(char* primes, uint64_t max)
   int blockSize = checkDevice();
   if (blockSize == EXIT_FAILURE)
      return;
   char* d_Primes = NULL;
   int sizePrimes = sizeof(char) * max;
   uint64_t maxRoot = sqrt(max);
   // allocate the primes on the device and set them to 0
   checkCudaErrors(cudaMalloc(&d_Primes, sizePrimes));
   checkCudaErrors(cudaMemset(d_Primes, 0, sizePrimes));
   // make sure that there are no errors...
   checkCudaErrors(cudaPeekAtLastError());
   // setup the execution configuration
   dim3 dimBlock(blockSize);
   dim3 dimGrid((maxRoot + dimBlock.x) / dimBlock.x);
   dim3 dimGridEvens(((max + dimBlock.x) / dimBlock.x) / 2);
   //////// debug
   #ifdef DEBUG
   printf("dimBlock(%d, %d, %d)\n", dimBlock.x, dimBlock.y, dimBlock.z);
   printf("dimGrid(%d, %d, %d)\n", dimGrid.x, dimGrid.y, dimGrid.z);
   printf("dimGridEvens(%d, %d, %d)\n", dimGridEvens.x, dimGridEvens.y, dimGridEvens.z);
   #endif
   // call the kernel
   // NOTE: no need to synchronize after each kernel
   // http://stackoverflow.com/a/11889641/2261947
   sieveInitCUDA<<<1, 1>>>(d_Primes); // launch a single thread to initialize
   sieveEvenNumbersCUDA<<<dimGridEvens, dimBlock>>>(d_Primes, max);
   sieveOfEratosthenesCUDA<<<dimGrid, dimBlock>>>(d_Primes, max, maxRoot);
   // check for kernel errors
   checkCudaErrors(cudaDeviceSynchronize());
   // copy the results back
   checkCudaErrors(cudaMemcpy(primes, d_Primes, sizePrimes, cudaMemcpyDeviceToHost));
   // no memory leaks
   checkCudaErrors(cudaFree(d_Primes));
If you’d like to test the code:
int main()
   int max = 85000000; // 85 million
   char* primes = malloc(max);
   // check that it allocated correctly...
   memset(primes, 0, max);
   genPrimesOnDevice(primes, max);
   // if you wish to display results:
   for (uint64_t i = 0; i < size; i++)
      if (primes[i] == 0) // if the value is '0', then the number is prime
         printf("%llu", i)
         if ((i + 1) != size)
            printf(", ");
   free(primes);
Ok, nevermind, I don’t know how to delete this thread, but someone has answered me on StackOverflow.
The problem is that I’m using X Window (linux) and I’m using the GPU for display as well.
[url]http://stackoverflow.com/a/24794547/2261947[/url]
He recommended me to checkout this document - [url]USING CUDA AND X | NVIDIA
The easiest way to do this is a hybrid cpu/gpu implementation like this really really simple version:
[url]http://pastebin.com/UNMstwEC[/url]
modestly faster than an optimized -O3 CPU version (4.0 Ghz)
