I have followed the step of the link https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-325/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/rootfs_custom.html#
I exec the command sudo ./apply_binaries.sh
, but the extlinux.conf is not different from this file on the board.
The extlinux.conf on the board is
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2
The custom is created by the script
TIMEOUT 30
DEFAULT primary
LABEL primary
LINUX /boot/Image
INITRD /boot/initrd
Is it correct?
The flash script will do the work and append more parameters to it.
Which parameters I should set? It’s tx2nx
sudo ./apply_binaries.sh --help
Use: apply_binaries.sh [--bsp|-b PATH] [--root|-r PATH] [--target-overlay] [--help|-h]
This script installs tegra binaries
Options are:
--bsp|-b PATH
bsp location (bsp, readme, installer)
--root|-r PATH
install toolchain to PATH
--target-overlay|-t
untar NVIDIA target overlay (.tbz2) instead of
pre-installing them as Debian packages
--help|-h
show this help
In my opinion, I can create a standard rootfs of tx2nx and then I can remove or add some files into the rootfs and then I will pack it
I mean the “flash.sh” script will append those parameters to your extlinux.conf after it flashed the board.
Ha
I see, now I can modify the rootfs.
How to create the rootfs and define the user name and password and auto login.
I mean how can I pack all the things in a system.img and flash it into the emmc and it will auto login all setting will be ok.
Similarly production mode, I can flash the image into emmc and it can run
Or is there any method to reduce the size of the rootfs?
There is a create user account script inside the BSP. You can use that first.
Check Linux_for_Tegra/tools.
Any docs to introduce the script?
L4T developer guide has the introduction.
Can you show me the link? I can find “l4t_create_default_user.sh” in the L4T developer guide has the introduction.
I use the same keyword from you and search it in the document.
Thanks! I got it. I can auto login.
But there is anther problem, I use nv_build_samplefs.sh
to download and extract the rootfs. Is there a script to config that which software I download. Because many software I don’t need.
I see that nvubuntu-bionic-aarch64-packages nvubuntu-bionic-aarch64-samplefs
kayccc
January 5, 2022, 2:11am
14
Is this still an issue to support? Further suggestions required? Thanks
kayccc
January 5, 2022, 5:06am
17
Great! Thanks for the confirmaton.
system
Closed
January 19, 2022, 5:07am
18
