FYI, some benchmark comparison using the Unigine "Heaven" GPU benchmark run on a Xenith 2 thin client on a Dell R720 under Windows 7 using the latest 331.59 GRID driver release:
Format | Frame | K140Q | K120Q | Score Difference
Type | size | FPS:AVE MIN MAX Score | FPS:AVE MIN MAX Score | K120Q vs. K140Q
OpenGL 800x600 24.5 7.3 41.3 618 | 23.5 7.3 37.1 593 | -4 %
DirectX11 1280x800 13.0 5.6 22.5 326 | 13.0 5.5 22.4 327 | 0 %
OpenGL 1280x960 10.5 5.1 17.8 254 | 8.6 3.7 13.9 216 | -15 %
The difference is that the K140Q setup allocates 1 GB of GPU memory and you can have a maximum of 16 vGPUs per NVIDIA GRID K1 card. The brand new K120Q format is limited to the same maximum frame size, but allocates just 512 MB of RAM and hence allows up to 32 vGPUs per board. By contrast the K100 also supported 32 vGPUs, but only with 256 MB of memory (hence, half the memory was going unused).
This demonstrates a minimum penalty for using the smaller configuration which even with large formats isn’t that much less, while essentially no difference with either smaller frames or the somewhat less demanding DirectX 11 format. In other words, this density supports as many users as the weaker K100 and sacrifices little performance compared with the K140Q. This is a nice and somewhat surprising result.
