• Hardware Platform (Jetson Orin Nano with Jetpack 6.1)
• DeepStream Version: 7.1
• JetPack Version (Jetpack 6.1)
• TensorRT Version 10.3
• Issue Type( question)
Hello nvs,
I use the Jetson Orin Nano to deploy bodypose3d with github deepstream_reference_apps/deepstream-bodypose-3d at master · NVIDIA-AI-IOT/deepstream_reference_apps · GitHub
Below is the log
seer@seer:/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-bodypose-3d/sources$ ./deepstream-pose-estimation-app --input file://$BODYPOSE3D_HOME/streams/bodypose.mp4 --output $BODYPOSE3D_HOME/streams/bodypose_3dbp.mp4 --focal 800.0 --width 1280 --height 720 --fps --save-pose $BODYPOSE3D_HOME/streams/bodypose_3dbp.json
Now playing: file:///opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-bodypose-3d/streams/bodypose.mp4
Setting min object dimensions as 16x16 instead of 1x1 to support VIC compute mode.
0:00:00.366455297 69963 0xaaaadcfd14f0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<secondary-nvinference-engine> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 2]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-7.1/sources/apps/sample_apps/deepstream-bodypose-3d/models/bodypose3dnet/bodypose3dnet_accuracy.onnx_b8_gpu0_fp16.engine
INFO: [FullDims Engine Info]: layers num: 9
0 INPUT kFLOAT input0 3x256x192 min: 1x3x256x192 opt: 8x3x256x192 Max: 8x3x256x192
1 INPUT kFLOAT k_inv 3x3 min: 1x3x3 opt: 8x3x3 Max: 8x3x3
2 INPUT kFLOAT t_form_inv 3x3 min: 1x3x3 opt: 8x3x3 Max: 8x3x3
3 INPUT kFLOAT scale_normalized_mean_limb_lengths 36 min: 1x36 opt: 8x36 Max: 8x36
4 INPUT kFLOAT mean_limb_lengths 36 min: 1x36 opt: 8x36 Max: 8x36
5 OUTPUT kFLOAT pose2d 34x3 min: 0 opt: 0 Max: 0
6 OUTPUT kFLOAT pose2d_org_img 34x3 min: 0 opt: 0 Max: 0
7 OUTPUT kFLOAT pose25d 34x4 min: 0 opt: 0 Max: 0
8 OUTPUT kFLOAT pose3d 34x3 min: 0 opt: 0 Max: 0
0:00:00.366646141 69963 0xaaaadcfd14f0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<secondary-nvinference-engine> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 2]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-7.1/sources/apps/sample_apps/deepstream-bodypose-3d/models/bodypose3dnet/bodypose3dnet_accuracy.onnx_b8_gpu0_fp16.engine
0:00:00.376978376 69963 0xaaaadcfd14f0 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<secondary-nvinference-engine> [UID 2]: Load new model:../configs/config_infer_secondary_bodypose3dnet.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
[NvMultiObjectTracker] Initialized
0:00:00.465781011 69963 0xaaaadcfd14f0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-7.1/sources/apps/sample_apps/deepstream-bodypose-3d/models/peoplenet/resnet34_peoplenet_int8.onnx_b1_gpu0_int8.engine
Implicit layer support has been deprecated
INFO: [Implicit Engine Info]: layers num: 0
0:00:00.465879441 69963 0xaaaadcfd14f0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-7.1/sources/apps/sample_apps/deepstream-bodypose-3d/models/peoplenet/resnet34_peoplenet_int8.onnx_b1_gpu0_int8.engine
0:00:00.468080797 69963 0xaaaadcfd14f0 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:../configs/config_infer_primary_peoplenet.txt sucessfully
Decodebin child added: source
Decodebin child added: decodebin0
Running...
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 279
NvMMLiteBlockCreate : Block : BlockType = 279
In cb_newpad
gstnvtracker: Unable to acquire a user meta buffer. Try increasing user-meta-pool-size
**PERF : FPS_0 (26.99)
**PERF : FPS_0 (15.49)
**PERF : FPS_0 (12.99)
**PERF : FPS_0 (11.24)
**PERF : FPS_0 (9.99)
**PERF : FPS_0 (9.33)
**PERF : FPS_0 (8.71)
**PERF : FPS_0 (8.37)
**PERF : FPS_0 (8.11)
**PERF : FPS_0 (7.89)
**PERF : FPS_0 (7.72)
**PERF : FPS_0 (7.57)
**PERF : FPS_0 (7.45)
**PERF : FPS_0 (7.35)
**PERF : FPS_0 (7.33)
**PERF : FPS_0 (7.18)
**PERF : FPS_0 (7.17)
**PERF : FPS_0 (7.10)
**PERF : FPS_0 (7.04)
**PERF : FPS_0 (6.99)
**PERF : FPS_0 (6.95)
**PERF : FPS_0 (6.91)
**PERF : FPS_0 (7.03)
**PERF : FPS_0 (6.96)
**PERF : FPS_0 (7.02)
**PERF : FPS_0 (7.05)
**PERF : FPS_0 (6.97)
**PERF : FPS_0 (6.94)
**PERF : FPS_0 (6.90)
**PERF : FPS_0 (6.93)
**PERF : FPS_0 (7.01)
**PERF : FPS_0 (6.98)
nvstreammux: Successfully handled EOS for source_id=0
**PERF : FPS_0 (0.00)
End of Stream
Returned, stopping playback
Deleting pipeline
[NvMultiObjectTracker] De-initialized
Can I know if the fps normal? Below is jtop
THanks,
