I’m trying run a TensorRT object detector at boot using the systemd method but I keep running into errors. My Jetson Nano 2GB is configured to auto-login to LXDE so I don’t have to input the password.
Build info. Jetpack 4.4.1
head -n 1 /etc/nv_tegra_release
#R32 (release), REVISION: 4.4, GCID: 23942405, BOARD: t210ref, EABI: aarch64, DATE: Fri Oct 16 19:44:43 UTC 2020
Here are the steps I took.
Created startup_detection_script.py
import os
os.system("cd /home/ag72/tensorrt_demos && python3 trt_ssd_async_ag.py --usb 0")
I tested it from the terminal and it runs fine.
Created custom_startup_detection_script_ag.service
in /home/ag72/Startup.
[Unit]
Description=Execute this on boot
After=multi-user.target
[Service]
Type=idle
ExecStart=/usr/bin/python3 /home/ag72/Startup/startup_detection_script.py
[Install]
WantedBy=multi-user.target
I also tried without After=multi-user.target
and without Type=idle
but I still got the same errors below.
Copied it to /etc/systemd/system.
sudo cp -i /home/ag72/Startup/custom_startup_detection_script_ag.service /etc/systemd/system
Then,
sudo systemctl start custom_startup_detection_script_ag
sudo systemctl status custom_startup_detection_script_ag
sudo systemctl enable custom_startup_detection_script_ag
Any time I edited, I did this.
sudo systemctl daemon-reload && sudo systemctl restart custom_startup_detection_script_ag
If I check the “status” as soon as it’s “started”, this is what I get.
custom_startup_detection_script_ag.service - Execute this on boot
Loaded: loaded (/etc/systemd/system/custom_startup_detection_script_ag.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2021-02-19 20:33:30 EST; 2s ago
Main PID: 8590 (python3)
Tasks: 6 (limit: 2282)
CGroup: /system.slice/custom_startup_detection_script_ag.service
├─8590 /usr/bin/python3 /home/ag72/Startup/startup_detection_script.py
├─8613 sh -c cd /home/ag72/tensorrt_demos ; python3 trt_ssd_async_ag.py --usb 0
└─8621 python3 trt_ssd_async_ag.py --usb 0
Feb 19 20:33:30 ag72 systemd[1]: Started Execute this on boot.
A few seconds later the LED on the webcam turns on only for a second. Then if I check the “status” again, this is what I get. I always get the OpenCV/Gstreamer warning when I run trt_ssd_async_ag.py
from a terminal but the webcam and objection detection run fine, so I just ignore it.
Active: inactive (dead) since Fri 2021-02-19 16:49:27 EST; 3h 21min ago
Process: 5363 ExecStart=/usr/bin/python3 /home/ag72/Startup/startup_detection_script.py (code=exited, status=0/SUCCESS)
Main PID: 5363 (code=exited, status=0/SUCCESS)
Feb 19 16:49:16 ag72 systemd[1]: Started Execute this on boot.
Feb 19 16:49:26 ag72 python3[5363]: [ WARN:0] global /tmp/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp (935) open OpenCV | GStreamer warning: Cannot query
Feb 19 16:49:26 ag72 python3[5363]: Unable to init server: Could not connect: Connection refused
Feb 19 16:49:26 ag72 python3[5561]: cannot open display:
I tried to incorporate some of the solutions in How to run a script on boot as well as adding startlxde
and export DISPLAY=:1.0
without any luck.
Any help is much appreciated.
