I see that in PGI 6.2, libpgbind.a is provided, but I am unable to link it statically. No matter whether -Bstatic, or -Bstatic_pgi are specified in the link step, libpgbind is always linked dynamically.
You can link libpgbind statically but 6.2 had it incorrectly placed in the dynamic section when linking with “-Bstatic_pgi”. This has been corrected in 7.0. However, libnuma must be linked dynamically.
You can work around this by adding the following line to your “.mypgf90rc”, “.mypgcpprc”, and “.mypgccrc” files in your “home” directory or “siterc” if you want the change to apply to everyone.
set LMP = $NUMAOBJS -l$(PREFIX)mp $PGINUMALIBS $PGIUNSTATIC $NUMALIBS $LTHREAD $PGISTATIC;
Alternatively, you can compile with “-v” (verbose), copy the link line, and move “-lpgbind” after “-Bstatic”.
Note that by linking libpgbind statically, your code will not run on systems that do not support NUMA.
