Hello everyone,
I have a small program, which was modified from “asyncAPI” example in the SDK.
The kernel first writes the input matrix, g_data, then sets a flag, flag, to indicate the completion. The host uses MemcpyAsync() and events to keep track the progress of the kernel, especially the flag.
However, the program will hang forever cause Memcpy always return a flag with 0xff. This is weird, cause this is not even the initial value of the flag, 0.
Can anyone help? Thank you very much.
#include <stdio.h>
#include <cutil_inline.h>
__global__ void increment_kernel(int *g_data, int * flag, int inc_value)
int i;
int idx = blockIdx.x * blockDim.x + threadIdx.x;
g_data[idx] = inc_value;
__threadfence();
/* a global barrier should be used here, however, I ignore this at this moment */
if (idx == 0)
* flag = 1;
int correct_output(int *data, const int n, const int x)
for(int i = 0; i < n; i++)
if(data[i] != x)
return 0;
return 1;
int main(int argc, char *argv[])
if( cutCheckCmdLineFlag(argc, (const char**)argv, "device") )
cutilDeviceInit(argc, argv);
else
cudaSetDevice( cutGetMaxGflopsDeviceId());
int n = 512;
int nbytes = n * sizeof(int);
int value = 26;
// allocate host memory
int *a = 0;
cutilSafeCall( cudaMallocHost((void**)&a, nbytes) );
memset(a, 0, nbytes);
int b = 0xff;
// allocate device memory
int *d_a=0;
cutilSafeCall( cudaMalloc((void**)&d_a, nbytes) );
cutilSafeCall( cudaMemset(d_a, 255, nbytes) );
int *d_b=0;
cutilSafeCall( cudaMalloc((void**)&d_b, sizeof(int)) );
cutilSafeCall( cudaMemset(d_b, 0, sizeof(int)) );
bool done = false;
// set kernel launch configuration
dim3 threads = dim3(512, 1);
dim3 blocks = dim3(1, 1);
// create cuda event handles
cudaEvent_t start, stop1, stop;
cutilSafeCall( cudaEventCreate(&start) );
cutilSafeCall( cudaEventCreate(&stop1) );
cutilSafeCall( cudaEventCreate(&stop) );
unsigned int timer;
cutilCheckError( cutCreateTimer(&timer) );
cutilCheckError( cutResetTimer(timer) );
cutilSafeCall( cudaThreadSynchronize() );
float gpu_time = 0.0f;
// asynchronously issue work to the GPU (all to stream 0)
cutilCheckError( cutStartTimer(timer) );
cudaEventRecord(start, 0);
cudaMemcpyAsync(d_a, a, nbytes, cudaMemcpyHostToDevice, 0);
increment_kernel<<<blocks, threads, 0, 0>>>(d_a, d_b, value);
do {
cudaMemcpyAsync((void *)&b, d_b, sizeof(int), cudaMemcpyDeviceToHost, 0);
cudaEventRecord(stop1, 0);
while (cudaEventQuery(stop1) == cudaErrorNotReady);
printf("b = %i\n", b);
if (b == 1)
done = true;
} while (!done);
cudaMemcpyAsync(a, d_a, nbytes, cudaMemcpyDeviceToHost, 0);
cudaEventRecord(stop, 0);
cutilCheckError( cutStopTimer(timer) );
unsigned long int counter=0;
while( cudaEventQuery(stop) == cudaErrorNotReady )
counter++;
cutilSafeCall( cudaEventElapsedTime(&gpu_time, start, stop) );
// print the cpu and gpu times
printf("time spent executing by the GPU: %.2f\n", gpu_time);
printf("time spent by CPU in CUDA calls: %.2f\n", cutGetTimerValue(timer) );
// check the output for correctness
printf("--------------------------------------------------------------\n");
if( correct_output(a, n, value) )
printf("Test PASSED\n");
else
printf("Test FAILED\n");
// release resources
cutilSafeCall( cudaEventDestroy(start) );
cutilSafeCall( cudaEventDestroy(stop) );
cutilSafeCall( cudaFreeHost(a) );
cutilSafeCall( cudaFree(d_a) );
cudaThreadExit();
cutilExit(argc, argv);
return 0;
