Subject: Request for NVIDIA NIM API Rate Limit Increase — AI Infrastructure Manager Development
Hello NVIDIA Team,
I would like to request a rate limit increase for my NVIDIA NIM API account.
Current limit: 40 RPM
Requested limit: 200 RPM
Acceptable fallback: 100–150 RPM if 200 RPM is not available
Use case: personal / development-stage AI infrastructure tooling, not public production traffic.
I am developing an All-in-One AI Infrastructure Manager for Windows. The goal of the project is to make it easier to launch, configure, and manage local and remote AI infrastructure in a modular way.
The main research and engineering goal of this project is to design infrastructure that can significantly improve the practical usefulness of smaller and mid-sized models by compensating for their weaknesses with a well-structured knowledge system, memory, RAG, project-specific context, rules, and tool orchestration.
Instead of relying only on larger frontier models, I am building a modular system where model capability can be amplified through better surrounding infrastructure:
  • RAG service management
  • Memory service management
  • MCP tool management per project
  • AI skill/module management
  • Global shared rule systems for agents
  • Per-project AI configuration
  • Agent workflow orchestration
  • Local service lifecycle management on Windows
  • Knowledge and context routing for different AI tasks
  • Testing different model backends for coding, planning, reasoning, and tool-use workflows
I use NVIDIA NIM as one of the main model backends for development and evaluation. One of my goals is to make NVIDIA NIM a first-class backend option inside this AI infrastructure manager, alongside other OpenAI-compatible providers. A higher development limit would help me test NIM more realistically in agentic workflows.
The models I am testing include:
  • moonshotai/kimi-k2.5
  • z-ai/glm-5.1
  • qwen/qwen3-coder-480b-a35b-instruct
  • openai/gpt-oss-120b
  • nvidia/nemotron-3-super-120b-a12b
Why the current 40 RPM limit is restrictive:
My workflow is agentic and tool-based. A single development task may require multiple model calls for planning, tool selection, project context inspection, RAG/memory interaction, MCP tool configuration, debugging service startup, validating configuration changes, and analyzing logs.
Even with a single developer and conservative usage, 40 RPM can be reached during normal testing because the system itself is designed around multi-step AI infrastructure orchestration rather than one-off chat completions.
This is not a public service, not customer-facing traffic, and not batch scraping. It is development and evaluation usage for an AI infrastructure management tool.
Current safeguards and mitigations:
  • Single-user development usage
  • Local throttling
  • One active agent workflow at a time
  • Conservative retries and backoff
  • No public API traffic
  • No abusive parallel workloads
  • Request budgeting in agent instructions
  • Preference for batching context gathering where possible
A higher limit would make NVIDIA NIM practical as a development backend for testing real agentic AI infrastructure workflows under Windows. The current 40 RPM limit is usable for simple chat, but restrictive for multi-step AI infrastructure orchestration, especially when testing RAG, memory, MCP tools, per-project agent configurations, and model capability amplification through external knowledge and tooling.
Thank you for considering my request.
