So this little piece of code worked fine and by the time I’d got rid of some errors in the cpp file I got the following error in the .cu file:
"Error 1 error C2059: syntax error : ‘<’ "
and a corresponding one for the line with kernel2 called in it
It has the same build configuration as before, in which it has compiled successfully, so am I missing something obvious here?
#include "GlobalStructs.h"
#include <string>
#include <iostream>
extern __global__ void kernel(element* particle, element* particle2, transport_map1* p_R, int mag_elements);
extern __global__ void kernel2(element* particle, element* particle2, transport_map2* p_T, int mag_elements);
void call_kernel(int num_threads, int num_blocks, element* particle, element* particle2, transport_map1* p_R, int mag_elements)
dim3 grid( num_blocks, 1, 1); //The number of blocks per grid
dim3 threads(num_threads, 1, 1); //The number of threads per block
kernel<<<grid,threads>>>(particle,
particle2,
p_R,
mag_elements);
void call_kernel(int num_threads, int num_blocks, element* particle, element* particle2, transport_map2* p_T, int mag_elements)
kernel2<<<grid,threads>>>(particle,
particle2,
p_T,
mag_elements);
