As stated, I just started a couple days ago with physx. I’m learning how to add static planes(working fine). Also static and dynamic boxes. I first added a dynamic box 10 units in the air and it falls just right and lands on a plane. Then I tried to add a static box to get in the original boxes way as it falls. The second static box should be positioned right on top of the plane but it seems to be positioning it relative to the dynamic box. So if I set the PxTransform p=PxVec3(0.0,1.0,0.0); it is positioned 1.0 units up from the dynamic boxes center. Instead of 1.0 units up from world origin.
for dynamic box creation IsDynamic=TRUE, FALSE for static:
PxTransform BT;
BT.createIdentity();
BT.p=PxVec3(NewEntity.Pos.X,NewEntity.Pos.Y,NewEntity.Pos.Z);
BT.q=PxQuat(0.0,0.0,0.0,1.0);
PxBoxGeometry BG;
BG.halfExtents=PxVec3(NewEntity.Verts[0].X,NewEntity.Verts[0].Y,NewEntity.Verts[0].Z);
if(!BT.isValid())
PRINT_ERROR("BOX TRANSFORM NOT VALID");
else
if(NewEntity.IsDynamic)
NewEntity.Dynamic=PxCreateDynamic(*World,BT,BG,*NewEntity.PMaterial,1.0);
if(!NewEntity.Dynamic)
PRINT_ERROR("DYNAMIC NOT CREATED!!!");
int SCount=(int)NewEntity.Dynamic->getNbShapes();
PxShape** SBuffer=new PxShape*[SCount];
NewEntity.Dynamic->getShapes(SBuffer,SCount,0);
for(int Counter=0;Counter < SCount;Counter++)
SBuffer[Counter]->setFlag(PxShapeFlag::eSIMULATION_SHAPE,true);
SBuffer[Counter]->setFlag(PxShapeFlag::eSCENE_QUERY_SHAPE,true);
PxRigidBodyExt::updateMassAndInertia(*NewEntity.Dynamic,1.0);
Scene->addActor(*NewEntity.Dynamic);
else
NewEntity.Static=PxCreateStatic(*World,BT,BG,*NewEntity.PMaterial);
NewEntity.Static->setActorFlag(PxActorFlag::eDISABLE_GRAVITY,true);
Scene->addActor(*NewEntity.Static);
Entities.push_back(NewEntity);
Any help is greatly appreciated
