Switching NVIDIA video super resolution on/off
With the new release of drivers 530+ and getting access to VSR, will the api eventually include a way to turn this feature on/off, as well as set the quality value? (Or, if I’m wrong and there’s already a way, please correct me and point me in the right direction)
Considering that it’s really inconvenient to open the control panel to adjust this every time, I want to make a cli utility which allows it to be adjusted on the fly. This feature, while awesome, can be very intensive, and would benefit from a quick and easy way to adjust it (through the api).
if this is currently not possible, may I request this be added to the api? It would be very invaluable for me and I’m sure others.
Dear @cherryleafroad
Thank you for contacting NVIDIA developer forum.
Our technical team has received your query and we will get back to you after initial investigation.
Thanks,
NVAPI Forum Moderator
Our technical team has informed that currently there is no feature available to change “Video Super Resolution” state through the NVAPI SDK. If this situation changes in future we will update accordingly.
Thank you.
