When copying files, the system suddenly freezes. Can someone tell me why this happens?
Jul 11 13:54:02 txkj-nx kernel: [ 3652.164258] tegra-xudc-new 3550000.xudc: entering ELPG
Jul 11 13:54:02 txkj-nx kernel: [ 3652.164657] tegra-xudc-new 3550000.xudc: entering ELPG done
Jul 11 13:54:02 txkj-nx kernel: [ 3652.192451] PM: suspend exit 2022-07-11 05:54:02.076509413 UTC
Jul 11 13:54:02 txkj-nx kernel: [ 3652.333631] tegradc 15210000.nvdisplay: blank - powerdown
Jul 11 13:54:02 txkj-nx kernel: [ 3652.333652] tegradc 15210000.nvdisplay: unblank
Jul 11 13:54:02 txkj-nx kernel: [ 3652.334535] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
Jul 11 13:54:02 txkj-nx kernel: [ 3652.334659] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
Jul 11 13:54:02 txkj-nx kernel: [ 3652.334772] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
Jul 11 13:54:02 txkj-nx kernel: [ 3652.336868] Parent Clock set for DC pll_d
Jul 11 13:54:02 txkj-nx kernel: [ 3652.340649] tegradc 15210000.nvdisplay: tegra_dp_get_bpp: vmode=0x200000 did not specify bpp
Jul 11 13:54:02 txkj-nx kernel: [ 3652.350778] dp lt: state 4 (link training fail/disable), pending_lt_evt 1
Jul 11 13:54:02 txkj-nx kernel: [ 3652.350800] dp lt: switching from state 4 (link training fail/disable) to state 0 (Reset)
Jul 11 13:54:02 txkj-nx kernel: [ 3652.350805] dp lt: state 0 (Reset), pending_lt_evt 0
Jul 11 13:54:02 txkj-nx kernel: [ 3652.352531] dp lt: switching from state 0 (Reset) to state 2 (clock recovery)
Jul 11 13:54:02 txkj-nx kernel: [ 3652.352537] dp lt: state 2 (clock recovery), pending_lt_evt 0
Jul 11 13:54:02 txkj-nx kernel: [ 3652.352999] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
Jul 11 13:54:02 txkj-nx kernel: [ 3652.353012] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
Jul 11 13:54:02 txkj-nx kernel: [ 3652.353021] dp lt: tx_pu: 0x20
Jul 11 13:54:02 txkj-nx kernel: [ 3652.353951] dp lt: CR done
Jul 11 13:54:02 txkj-nx kernel: [ 3652.353955] dp lt: switching from state 2 (clock recovery) to state 3 (channel equalization)
Jul 11 13:54:02 txkj-nx kernel: [ 3652.353959] dp lt: state 3 (channel equalization), pending_lt_evt 0
Jul 11 13:54:02 txkj-nx kernel: [ 3652.355919] dp lt: CE done
Jul 11 13:54:02 txkj-nx kernel: [ 3652.355922] dp lt: switching from state 3 (channel equalization) to state 5 (link training pass)
Jul 11 13:54:02 txkj-nx kernel: [ 3652.355983] tegradc 15210000.nvdisplay: unblank
Jul 11 13:54:02 txkj-nx kernel: [ 3652.355996] tegradc 15200000.nvdisplay: blank - powerdown
Jul 11 13:54:02 txkj-nx kernel: [ 3652.377469] tegradc 15210000.nvdisplay: unblank
Jul 11 13:54:02 txkj-nx kernel: [ 3652.377486] tegradc 15200000.nvdisplay: blank - powerdown
Jul 11 13:54:02 txkj-nx kernel: [ 3652.396293] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
Jul 11 13:54:02 txkj-nx kernel: [ 3652.428578] eqos 2490000.ether_qos eth0: Link is Down
Jul 11 13:54:03 txkj-nx kernel: [ 3654.000615] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Jul 11 13:54:07 txkj-nx kernel: [ 3657.868538] FAN rising trip_level:1 cur_temp:50800 trip_temps[2]:60000
Jul 11 13:54:36 txkj-nx kernel: [ 3686.785458] tegra-xudc-new 3550000.xudc: exiting ELPG
Jul 11 13:54:36 txkj-nx kernel: [ 3686.785510] android_work: did not send uevent (0 0 (null))
Jul 11 13:54:36 txkj-nx kernel: [ 3686.786149] tegra-xudc-new 3550000.xudc: exiting ELPG done
Jul 11 13:54:36 txkj-nx kernel: [ 3686.786237] tegra-xudc-new 3550000.xudc: ep 0 disabled
Jul 11 13:54:36 txkj-nx kernel: [ 3686.786270] tegra-xudc-new 3550000.xudc: entering ELPG
Jul 11 13:54:36 txkj-nx kernel: [ 3686.786592] tegra-xudc-new 3550000.xudc: entering ELPG done
Jul 11 13:54:36 txkj-nx kernel: [ 3686.907777] Mass Storage Function, version: 2009/09/11
Jul 11 13:54:36 txkj-nx kernel: [ 3686.907788] LUN: removable file: (no medium)
Jul 11 13:54:36 txkj-nx kernel: [ 3686.918622] tegra-xudc-new 3550000.xudc: exiting ELPG
Jul 11 13:54:36 txkj-nx kernel: [ 3686.919245] tegra-xudc-new 3550000.xudc: exiting ELPG done
Jul 11 13:54:36 txkj-nx kernel: [ 3686.919269] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
Jul 11 13:54:36 txkj-nx kernel: [ 3686.919308] tegra-xudc-new 3550000.xudc: entering ELPG
Jul 11 13:54:36 txkj-nx kernel: [ 3686.919535] tegra-xudc-new 3550000.xudc: entering ELPG done
Jul 11 13:54:36 txkj-nx kernel: [ 3686.919550] tegra-xudc-new 3550000.xudc: exiting ELPG
Jul 11 13:54:36 txkj-nx kernel: [ 3686.920025] tegra-xudc-new 3550000.xudc: exiting ELPG done
Jul 11 13:54:36 txkj-nx kernel: [ 3686.920042] tegra-xudc-new 3550000.xudc: entering ELPG
Jul 11 13:54:36 txkj-nx kernel: [ 3686.920281] tegra-xudc-new 3550000.xudc: entering ELPG done
Jul 11 13:54:48 txkj-nx kernel: [ 3698.332260] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
Jul 11 13:54:48 txkj-nx kernel: [ 3698.332393] tegra-xudc-new 3550000.xudc: vbus state: 1
Jul 11 13:54:48 txkj-nx kernel: [ 3698.332408] tegra-xudc-new 3550000.xudc: exiting ELPG
Jul 11 13:54:48 txkj-nx kernel: [ 3698.333038] tegra-xudc-new 3550000.xudc: exiting ELPG done
Jul 11 13:54:48 txkj-nx kernel: [ 3698.333060] tegra-xudc-new 3550000.xudc: device mode on: 0
Jul 11 13:54:48 txkj-nx kernel: [ 3698.333080] tegra-xudc-new 3550000.xudc: active: 0 => 1
Jul 11 13:54:48 txkj-nx kernel: [ 3698.488503] android_work: did not send uevent (0 0 (null))
Jul 11 13:54:48 txkj-nx kernel: [ 3698.521386] android_work: sent uevent USB_STATE=CONNECTED
Jul 11 13:54:48 txkj-nx kernel: [ 3698.572028] configfs-gadget gadget: high-speed config #1: c
Jul 11 13:54:48 txkj-nx kernel: [ 3698.572118] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
Jul 11 13:54:48 txkj-nx kernel: [ 3698.572138] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
Jul 11 13:54:48 txkj-nx kernel: [ 3698.572292] android_work: sent uevent USB_STATE=CONFIGURED
Jul 11 13:54:48 txkj-nx kernel: [ 3698.708499] tegra-xudc-new 3550000.xudc: setup request failed: -22
Jul 11 13:55:57 txkj-nx kernel: [ 3767.183369] nvme nvme0: async event result 00020101
Jul 11 14:02:51 txkj-nx kernel: [ 4181.372558] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
Jul 11 14:02:51 txkj-nx kernel: [ 4181.372575] tegra-xudc-new 3550000.xudc: vbus state: 0
Jul 11 14:02:51 txkj-nx kernel: [ 4181.372583] tegra-xudc-new 3550000.xudc: device mode off: 0
Jul 11 14:02:51 txkj-nx kernel: [ 4181.372724] tegra-xudc-new 3550000.xudc: active: 1 => 0
Jul 11 14:02:51 txkj-nx kernel: [ 4181.372776] android_work: sent uevent USB_STATE=DISCONNECTED
Jul 11 14:02:51 txkj-nx kernel: [ 4181.372821] tegra-xudc-new 3550000.xudc: entering ELPG
Jul 11 14:02:51 txkj-nx kernel: [ 4181.373200] tegra-xudc-new 3550000.xudc: entering ELPG done
Jul 11 14:02:52 txkj-nx kernel: [ 4182.402522] tegra-xudc-new 3550000.xudc: exiting ELPG
Jul 11 14:02:52 txkj-nx kernel: [ 4182.402588] android_work: did not send uevent (0 0 (null))
Jul 11 14:02:52 txkj-nx kernel: [ 4182.403271] tegra-xudc-new 3550000.xudc: exiting ELPG done
Jul 11 14:02:52 txkj-nx kernel: [ 4182.403343] tegra-xudc-new 3550000.xudc: ep 0 disabled
Jul 11 14:02:52 txkj-nx kernel: [ 4182.403363] tegra-xudc-new 3550000.xudc: entering ELPG
Jul 11 14:02:52 txkj-nx kernel: [ 4182.403612] tegra-xudc-new 3550000.xudc: entering ELPG done
Jul 11 14:02:55 txkj-nx kernel: [ 4185.639552] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jul 11 14:02:58 txkj-nx kernel: [ 4189.036697] ------------[ cut here ]------------
Jul 11 14:02:58 txkj-nx kernel: [ 4189.036841] WARNING: CPU: 1 PID: 43 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/block/blk-mq.c:792 __blk_mq_run_hw_queue+0x374/0x3d0
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037061] Modules linked in: fuse virmouse(O) zram binfmt_misc uvcvideo userspace_alert nvgpu ip_tables x_tables
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037104]
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037133] CPU: 1 PID: 43 Comm: kworker/5:0H Tainted: G O 4.9.253-tegra #1
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037139] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037154] Workqueue: kblockd blk_mq_run_work_fn
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037165] task: ffffffc1f5e11c00 task.stack: ffffffc1f5e24000
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037173] PC is at __blk_mq_run_hw_queue+0x374/0x3d0
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037181] LR is at blk_mq_run_work_fn+0x20/0x30
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037190] pc : [<ffffff8008439d4c>] lr : [<ffffff8008439e08>] pstate: 60c00045
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037195] sp : ffffffc1f5e27ca0
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037200] x29: ffffffc1f5e27ca0 x28: 0000000000000000
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037213] x27: ffffffc1e01f8000 x26: ffffffc1ffd849c0
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037225] x25: ffffff800a0ba000 x24: 0000000000000000
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037236] x23: 0000000000000000 x22: ffffffc1f5e27d18
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037248] x21: ffffffc1ffd849c0 x20: ffffffc1e000d200
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037260] x19: ffffffc1e000d240 x18: 0000000000000000
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037272] x17: 0000007fa0c35d40 x16: 0000000000000000
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037284] x15: 0000000000000003 x14: 0000000000e7af36
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037296] x13: 0000000002d9fbf3 x12: 0000000000000400
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037307] x11: 0000000000000400 x10: 0000000000000a10
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037328] x9 : ffffffc1f5e27d10 x8 : ffffffc1f5e12670
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037345] x7 : 0000000000000400 x6 : 0000000000000400
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037362] x5 : 0000000000000400 x4 : 0000000000000000
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037379] x3 : ffffffc1f5e11c00 x2 : ffffff8009e86e38
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037396] x1 : 000000000000000f x0 : 000000000000000f
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037410]
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037415] ---[ end trace 436abd3b9e08208d ]---
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037499] Call trace:
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037509] [<ffffff8008439d4c>] __blk_mq_run_hw_queue+0x374/0x3d0
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037517] [<ffffff8008439e08>] blk_mq_run_work_fn+0x20/0x30
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037527] [<ffffff80080d40ac>] process_one_work+0x1e4/0x4b0
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037535] [<ffffff80080d43c8>] worker_thread+0x50/0x4c8
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037543] [<ffffff80080db09c>] kthread+0xec/0xf0
Jul 11 14:02:58 txkj-nx kernel: [ 4189.037551] [<ffffff80080838a0>] ret_from_fork+0x10/0x30
Jul 11 14:03:04 txkj-nx kernel: [ 4194.588721] ------------[ cut here ]------------
Jul 11 14:03:04 txkj-nx kernel: [ 4194.588875] WARNING: CPU: 2 PID: 24797 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/block/blk-mq.c:792 __blk_mq_run_hw_queue+0x374/0x3d0
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589110] Modules linked in: fuse virmouse(O) zram binfmt_misc uvcvideo userspace_alert nvgpu ip_tables x_tables
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589155]
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589182] CPU: 2 PID: 24797 Comm: kworker/5:2H Tainted: G W O 4.9.253-tegra #1
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589190] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589204] Workqueue: kblockd blk_mq_run_work_fn
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589216] task: ffffffc1f5bae200 task.stack: ffffffc11399c000
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589225] PC is at __blk_mq_run_hw_queue+0x374/0x3d0
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589232] LR is at blk_mq_run_work_fn+0x20/0x30
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589241] pc : [<ffffff8008439d4c>] lr : [<ffffff8008439e08>] pstate: 60c00045
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589245] sp : ffffffc11399fca0
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589250] x29: ffffffc11399fca0 x28: 0000000000000000
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589263] x27: ffffffc1e01f8000 x26: ffffffc1ffd849c0
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589275] x25: ffffff800a0ba000 x24: 0000000000000000
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589287] x23: 0000000000000000 x22: ffffffc11399fd18
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589299] x21: ffffffc1ffd849c0 x20: ffffffc1e000d200
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589311] x19: ffffffc1e000d240 x18: 0000007f8fc2ea70
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589323] x17: 0000007f8fb9d858 x16: ffffff800825c7f0
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589335] x15: 000000002134e450 x14: 0efc1f6d9a746c2c
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589347] x13: 0000000000001a00 x12: 0000000000000000
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589359] x11: 0000000000000a00 x10: ffffffc11547a850
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589380] x9 : 00000000fffffa00 x8 : 00000004fc8e0000
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589398] x7 : 0000000000082167 x6 : 0000000000000a00
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589415] x5 : 0000000000000000 x4 : 0000000000000000
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589432] x3 : 0000000000000000 x2 : ffffff8009e86e38
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589450] x1 : 000000000000000f x0 : 000000000000000f
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589464]
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589469] ---[ end trace 436abd3b9e08208e ]---
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589553] Call trace:
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589564] [<ffffff8008439d4c>] __blk_mq_run_hw_queue+0x374/0x3d0
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589572] [<ffffff8008439e08>] blk_mq_run_work_fn+0x20/0x30
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589582] [<ffffff80080d40ac>] process_one_work+0x1e4/0x4b0
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589590] [<ffffff80080d45e0>] worker_thread+0x268/0x4c8
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589598] [<ffffff80080db09c>] kthread+0xec/0xf0
Jul 11 14:03:04 txkj-nx kernel: [ 4194.589607] [<ffffff80080838a0>] ret_from_fork+0x10/0x30
Jul 11 14:03:05 txkj-nx kernel: [ 4195.116543] ------------[ cut here ]------------
Jul 11 14:03:05 txkj-nx kernel: [ 4195.116691] WARNING: CPU: 1 PID: 24797 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/block/blk-mq.c:792 __blk_mq_run_hw_queue+0x374/0x3d0
Jul 11 14:03:05 txkj-nx kernel: [ 4195.116932] Modules linked in: fuse virmouse(O) zram binfmt_misc uvcvideo userspace_alert nvgpu ip_tables x_tables
Jul 11 14:03:05 txkj-nx kernel: [ 4195.116976]
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117017] CPU: 1 PID: 24797 Comm: kworker/5:2H Tainted: G W O 4.9.253-tegra #1
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117025] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117039] Workqueue: kblockd blk_mq_run_work_fn
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117049] task: ffffffc1f5bae200 task.stack: ffffffc11399c000
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117057] PC is at __blk_mq_run_hw_queue+0x374/0x3d0
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117064] LR is at blk_mq_run_work_fn+0x20/0x30
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117074] pc : [<ffffff8008439d4c>] lr : [<ffffff8008439e08>] pstate: 60c00045
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117078] sp : ffffffc11399fca0
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117084] x29: ffffffc11399fca0 x28: 0000000000000000
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117097] x27: ffffffc1e01f8000 x26: ffffffc1ffd849c0
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117109] x25: ffffff800a0ba000 x24: 0000000000000000
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117121] x23: 0000000000000000 x22: ffffffc11399fd18
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117133] x21: ffffffc1ffd849c0 x20: ffffffc1e000d200
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117145] x19: ffffffc1e000d240 x18: 0000007fa8175a70
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117157] x17: 0000007fa8084ed0 x16: 0000000000000000
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117169] x15: 0000000000000233 x14: 0000000000000400
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117181] x13: 0000000000000000 x12: 0000000000000000
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117193] x11: 0000000000000000 x10: 0000000000000a10
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117212] x9 : ffffffc11399fd10 x8 : ffffffc1f5baec70
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117230] x7 : 0000000000045400 x6 : 000000342011e6ec
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117247] x5 : 0000000000000000 x4 : 0000000000000000
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117264] x3 : ffffffc1f5bae200 x2 : ffffff8009e86e38
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117282] x1 : 000000000000000f x0 : 000000000000000f
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117296]
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117301] ---[ end trace 436abd3b9e08208f ]---
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117385] Call trace:
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117395] [<ffffff8008439d4c>] __blk_mq_run_hw_queue+0x374/0x3d0
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117403] [<ffffff8008439e08>] blk_mq_run_work_fn+0x20/0x30
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117414] [<ffffff80080d40ac>] process_one_work+0x1e4/0x4b0
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117422] [<ffffff80080d43c8>] worker_thread+0x50/0x4c8
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117430] [<ffffff80080db09c>] kthread+0xec/0xf0
Jul 11 14:03:05 txkj-nx kernel: [ 4195.117438] [<ffffff80080838a0>] ret_from_fork+0x10/0x30
Jul 11 14:03:14 txkj-nx kernel: [ 4204.128551] ------------[ cut here ]------------
Jul 11 14:03:14 txkj-nx kernel: [ 4204.128692] WARNING: CPU: 2 PID: 24797 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/block/blk-mq.c:792 __blk_mq_run_hw_queue+0x374/0x3d0
Jul 11 14:03:14 txkj-nx kernel: [ 4204.128904] Modules linked in: fuse virmouse(O) zram binfmt_misc uvcvideo userspace_alert nvgpu ip_tables x_tables
Jul 11 14:03:14 txkj-nx kernel: [ 4204.128949]
Jul 11 14:03:14 txkj-nx kernel: [ 4204.128979] CPU: 2 PID: 24797 Comm: kworker/5:2H Tainted: G W O 4.9.253-tegra #1
Jul 11 14:03:14 txkj-nx kernel: [ 4204.128987] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129001] Workqueue: kblockd blk_mq_run_work_fn
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129011] task: ffffffc1f5bae200 task.stack: ffffffc11399c000
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129019] PC is at __blk_mq_run_hw_queue+0x374/0x3d0
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129026] LR is at blk_mq_run_work_fn+0x20/0x30
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129035] pc : [<ffffff8008439d4c>] lr : [<ffffff8008439e08>] pstate: 60c00045
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129040] sp : ffffffc11399fca0
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129045] x29: ffffffc11399fca0 x28: 0000000000000000
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129058] x27: ffffffc1e01f8000 x26: ffffffc1ffd849c0
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129070] x25: ffffff800a0ba000 x24: 0000000000000000
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129081] x23: 0000000000000000 x22: ffffffc11399fd18
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129094] x21: ffffffc1ffd849c0 x20: ffffffc1e000d200
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129105] x19: ffffffc1e000d240 x18: 0000007f8d9f5a70
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129117] x17: 0000007f8dae6070 x16: ffffff800814eaf8
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129129] x15: 0000000000000000 x14: 000000000000000f
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129141] x13: 0000000000000019 x12: 071c71c71c71c71c
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129153] x11: 000000000000000b x10: 0000000000000a10
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129172] x9 : ffffffc11399fd10 x8 : ffffffc1f5baec70
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129189] x7 : 0000000000000000 x6 : ffffffc1ffd396f8
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129215] x5 : 0000000000000000 x4 : 0000000000000000
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129232] x3 : ffffffc1f5bae200 x2 : ffffff8009e86e38
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129249] x1 : 000000000000000f x0 : 000000000000000f
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129263]
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129268] ---[ end trace 436abd3b9e082090 ]---
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129355] Call trace:
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129366] [<ffffff8008439d4c>] __blk_mq_run_hw_queue+0x374/0x3d0
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129374] [<ffffff8008439e08>] blk_mq_run_work_fn+0x20/0x30
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129384] [<ffffff80080d40ac>] process_one_work+0x1e4/0x4b0
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129392] [<ffffff80080d43c8>] worker_thread+0x50/0x4c8
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129400] [<ffffff80080db09c>] kthread+0xec/0xf0
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129409] [<ffffff80080838a0>] ret_from_fork+0x10/0x30
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129704] ------------[ cut here ]------------
Jul 11 14:03:14 txkj-nx kernel: [ 4204.129802] WARNING: CPU: 2 PID: 24797 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/block/blk-mq.c:792 __blk_mq_run_hw_queue+0x374/0x3d0
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130017] Modules linked in: fuse virmouse(O) zram binfmt_misc uvcvideo userspace_alert nvgpu ip_tables x_tables
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130057]
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130073] CPU: 2 PID: 24797 Comm: kworker/5:2H Tainted: G W O 4.9.253-tegra #1
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130079] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130090] Workqueue: kblockd blk_mq_run_work_fn
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130099] task: ffffffc1f5bae200 task.stack: ffffffc11399c000
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130106] PC is at __blk_mq_run_hw_queue+0x374/0x3d0
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130113] LR is at blk_mq_run_work_fn+0x20/0x30
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130120] pc : [<ffffff8008439d4c>] lr : [<ffffff8008439e08>] pstate: 60c00045
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130124] sp : ffffffc11399fca0
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130129] x29: ffffffc11399fca0 x28: 0000000000000000
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130142] x27: ffffffc1e01f8000 x26: ffffffc1ffd849c0
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130154] x25: ffffff800a0ba000 x24: 0000000000000000
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130166] x23: 0000000000000000 x22: ffffffc11399fd18
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130178] x21: ffffffc1ffd849c0 x20: ffffffc1e000d200
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130190] x19: ffffffc1e000d240 x18: 0000007f8d9f5a70
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130202] x17: 0000007f8dae6070 x16: ffffff800814eaf8
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130214] x15: 0000000000000000 x14: 000000000000000f
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130225] x13: 0000000000002000 x12: 0000000000000000
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130237] x11: 0000000000001000 x10: 0000000000001000
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130255] x9 : 0000000000000000 x8 : 00000004ffd98000
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130280] x7 : 0000000000082167 x6 : 0000000000001000
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130298] x5 : 0000000000000000 x4 : 0000000000000000
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130315] x3 : 0000000000000000 x2 : ffffff8009e86e38
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130331] x1 : 000000000000000f x0 : 000000000000000f
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130345]
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130350] ---[ end trace 436abd3b9e082091 ]---
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130439] Call trace:
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130450] [<ffffff8008439d4c>] __blk_mq_run_hw_queue+0x374/0x3d0
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130459] [<ffffff8008439e08>] blk_mq_run_work_fn+0x20/0x30
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130467] [<ffffff80080d40ac>] process_one_work+0x1e4/0x4b0
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130475] [<ffffff80080d45e0>] worker_thread+0x268/0x4c8
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130482] [<ffffff80080db09c>] kthread+0xec/0xf0
Jul 11 14:03:14 txkj-nx kernel: [ 4204.130489] [<ffffff80080838a0>] ret_from_fork+0x10/0x30
Jul 11 14:07:54 txkj-nx kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Jul 11 14:07:54 txkj-nx kernel: [ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5497-d3000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Jul 26 12:19:28 PDT 2021
Jul 11 14:07:54 txkj-nx kernel: [ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
Jul 11 14:07:54 txkj-nx kernel: [ 0.000000] OF: fdt:memory scan node memory, reg size 48,
Jul 11 14:07:54 txkj-nx kernel: [ 0.000000] OF: fdt: - 80000000 , 2c000000
Jul 11 14:07:54 txkj-nx kernel: [ 0.000000] OF: fdt: - ac200000 , 44800000
Jul 11 14:07:54 txkj-nx kernel: [ 0.000000] OF: fdt: - 100000000 , 180000000
Jul 11 14:07:54 txkj-nx kernel: [ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x0000000
