System-wide atomic operation failure on multi-4090 systems
I would like to share my sample code here which exposes erroneous behaviors of multi-4090 systems.
https://github.com/mino-hidetoshi/System-wide_Atomic
As far as I tested, it produces non-deterministic results when running on multi-4090 system as follows:
Compilation:
$ nvcc -arch=sm_60 atomic-01.cu
Execution examples:
# single 4090 execution
$ CUDA_VISIBLE_DEVICES=0 ./a.out
atomic-01.cu
5000000
# dual 4090 execution
$ CUDA_VISIBLE_DEVICES=0,1 ./a.out
atomic-01.cu
5000269
I would like to know if this is common to all multi-4090 environments.
I have tested some instances on cloud GPUs and got this non-deterministic results WITH NO EXCEPTION. How about yours?
Multi-3090 systems ( or older ) always produce the right result of 5000000.
---- added on 2023/02/19
In the sample code, kernel updates managed variables repeatedly by atomicAdd_system(). If the atomic operation works correctly, the result should be 5000000. If the atomicity is broken, the results become unpredictable.
I have now found this multi-4090 issue is docker image dependent.
Three examples I tested follow:
nvidia/cuda_11.3.0-devel-ubuntu18.04 : No good
nvidia/cuda_11.3.0-devel-ubuntu20.04 : Good
nvidia/cuda_12.0.0-devel-ubuntu22.04 : No good
Ubuntu22 image is known to be problematic.
Older versions also seem to be unreliable.
In summary, this is not likely a GPU issue but a docker issue.
Sorry , If I bothered you.
