FYI, gcloud beta ai custom-jobs local-run
fails as well with the same exception as above.
Can you share the full command you are running? Full log is also appreciated.
More, could you please run below under TAO3.0 and Google Vertex AI environment?
- $ nvidia-smi
- $ python
>>> from modulus.export._tensorrt import ONNXEngineBuilder
Please share me with the result. Thanks.
Tue Oct 12 12:12:48 2021
| NVIDIA-SMI 450.51.06 Driver Version: 450.51.06 CUDA Version: 11.0 |
| | | MIG M. |
| 0 Tesla P100-PCIE... On | 00000000:00:04.0 Off | 0 |
| N/A 33C P0 32W / 250W | 0MiB / 16280MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
It appears the nvidia-driver is not updated enough. Just curious, why was this broken between TLT 2.0 and TAo 3.0?
@Morganh does the nvidia-driver version get inherited from the host operating system?
FYI here is the machine spec for my training job:
"workerPoolSpecs": [
"machineSpec": {
"machineType": "n1-standard-4",
"acceleratorType": "NVIDIA_TESLA_P100",
"acceleratorCount": 1
"replicaCount": "1",
"diskSpec": {
"bootDiskType": "pd-ssd",
"bootDiskSizeGb": 100
"containerSpec": {
"imageUri": "<my custom container based on TAO>",
"command": [
"nvidia-smi"
I will try the other machineType
and acceleratorType
options to see if they use the newer nvidia driver.
Yes, the nvidia-driver version gets inherited from the host operating system. For TAO 3.0, please meet software requirement to avoid unexpected error. For example, Nvidia TAO cuda version error - #3 by anil.vuppala
Until Google updates the version of the nvidia driver used on their servers that run the Vertex Ai containers, the newest release of TAO does not work on that platform.
We cannot upgrade until this is supported.
Thanks for the info.
