TAO converter for linux Ubuntu 20.04
Hi
When i try to download the binary exec for TAO converter for the x86 linux ubuntu 20.04 from the nvidia following site
TAO Converter | NVIDIA NGC
I am not able to download the correct arch version file for tensorrt 8.4. When the download link is clicked for x86 only aarch64 format is downloading not the correct binary exec.
Hi, Thanks for posting in the forums. I am looking for the owner of the NGC page. I will post back here when I have more information.
Best,
Tom
@gayathri4
Can you double check? I cannot reproduce this issue.
yes I have rechecked it. When i try to download trt 8.4 version for x86 device, aarch file is getting downloading
Can you try β€œwget” command? See below.
yes wget command works. but getting the following error for converting etlt model.
[INFO] [MemUsageChange] Init CUDA: CPU +724, GPU +0, now: CPU 730, GPU 311 (MiB)
[INFO] ----------------------------------------------------------------
[INFO] Input filename: /tmp/fileFclIhk
[INFO] ONNX IR version: 0.0.7
[INFO] Opset version: 13
[INFO] Producer name: pytorch
[INFO] Producer version: 1.10
[INFO] Domain:
[INFO] Model version: 0
[INFO] Doc string:
[WARNING] onnx2trt_utils.cpp:320: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[WARNING] Tensor DataType is determined at build time for tensors not marked as input or output.
[ERROR] [graphShapeAnalyzer.cpp::throwIfError::1306] Error Code 9: Internal Error (Gather_218: index to gather must not exceed length of vector
[ERROR] ModelImporter.cpp:738: While parsing node number 220 [Range β†’ β€œ537”]:
[ERROR] ModelImporter.cpp:739: β€” Begin node β€”
[ERROR] ModelImporter.cpp:740: input: β€œ935”
input: β€œ535”
input: β€œ936”
output: β€œ537”
op_type: β€œRange”
[ERROR] ModelImporter.cpp:741: β€” End node β€”
[ERROR] ModelImporter.cpp:744: ERROR: ModelImporter.cpp:197 In function parseGraph:
[6] Invalid Node - Range_220
[ERROR] Failed to parse the model, please check the encoding key to make sure it’s correct
[INFO] Detected input dimensions from the model: (1, 3, 576, 960)
[INFO] Model has no dynamic shape.
[INFO] [MemUsageSnapshot] Builder begin: CPU 797 MiB, GPU 311 MiB
[ERROR] 4: [network.cpp::validate::2361] Error Code 4: Internal Error (Network must have at least one output)
[ERROR] Unable to create engine
OK, so original issue is gone.
For latest error, can you share the full commandline?
I need to convert etlt model to tensorrt engine using tao converter.
./tao-converter_8.4 -k ess -t fp16 -e ./ess.engine -o output_left ess.etlt
[INFO] [MemUsageChange] Init CUDA: CPU +736, GPU +0, now: CPU 742, GPU 311 (MiB)
[INFO] Input filename: /tmp/file2dQUqh
[INFO] Domain:
[INFO] Doc string:
input: β€œ535”
input: β€œ936”
output: β€œ537”
op_type: β€œRange”
[INFO] [MemUsageSnapshot] Builder begin: CPU 809 MiB, GPU 311 MiB
Which network did you use to train to get this model?
Hi Morgan
This model was downloaded one from ess dnn stereo of nvidia
It is not a model mentioned in TAO user guide.
To narrow down, could you try its old version? GPU-optimized AI, Machine Learning, & HPC Software | NVIDIA NGC | NVIDIA NGC
Hi
Tried the old version getting same error
Hi
The same converter for jetpack is workign in jetson nano board. Problem is in x86 platform.
So, there is no issue in Jetson nano when you use aarch version of tao-converter, correct?
