Tao-converter not working for custom pointpillars
Hi, I’ve trained the PointPillarNet using a custom dataset with the following spec file
pointpillars_exp1_128.yaml (4.8 KB)
and I used the following weight
checkpoint_epoch_100.tlt (58.4 MB)
When I run the command
pointpillars export -m checkpoint_epoch_100.tlt -k perception -o tao_custom_128.etlt -e pointpillars_exp1_128.yaml
it works fine, but when I want to convert it to tensor_rt file using the command
tao-converter tao_custom_128.etlt -k perception -e trt.engine -p points,1x25000x4,1x25000x4,1x204800x4 -p num_points,1,1,1 it does not work and it says:
[ERROR] ModelImporter.cpp:743: — End node —
[ERROR] ModelImporter.cpp:746: ERROR: builtin_op_importers.cpp:5374 In function importFallbackPluginImporter:
[8] Assertion failed: plugin && “Could not create plugin”
[ERROR] Failed to parse the model, please check the encoding key to make sure it’s correct
[INFO] Detected input dimensions from the model: (-1, 25000, 4)
[INFO] Detected input dimensions from the model: (-1)
[INFO] Model has dynamic shape. Setting up optimization profiles.
[INFO] Using optimization profile min shape: (1, 25000, 4) for input: points
[INFO] Using optimization profile opt shape: (1, 25000, 4) for input: points
[INFO] Using optimization profile max shape: (1, 204800, 4) for input: points
[INFO] Using optimization profile min shape: (1) for input: num_points
[INFO] Using optimization profile opt shape: (1) for input: num_points
[INFO] Using optimization profile max shape: (1) for input: num_points
[ERROR] 4: [network.cpp::validate::2738] Error Code 4: Internal Error (Network must have at least one output)
Does someone know how to fix it?
Just as info, I’m using the nvidia-docker image for tao-toolkit.
Try this comand
tao-converter tao_custom_128.etlt -k perception -e trt.engine -p points,1x25000x4,1x25000x4,1x25000x4 -p num_points,1,1,1
It still doesn’t work, this what I get now:
[INFO] [MemUsageChange] Init CUDA: CPU +12, GPU +0, now: CPU 24, GPU 78 (MiB)
[INFO] [MemUsageChange] Init builder kernel library: CPU +264, GPU +74, now: CPU 340, GPU 152 (MiB)
[INFO] ----------------------------------------------------------------
[INFO] Input filename: /tmp/file0mo25a
[INFO] ONNX IR version: 0.0.8
[INFO] Opset version: 11
[INFO] Producer name: pytorch
[INFO] Producer version: 1.13.0
[INFO] Domain:
[INFO] Model version: 0
[INFO] Doc string:
[WARNING] onnx2trt_utils.cpp:377: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[INFO] No importer registered for op: VoxelGeneratorPlugin. Attempting to import as plugin.
[INFO] Searching for plugin: VoxelGeneratorPlugin, plugin_version: 1, plugin_namespace:
[INFO] Successfully created plugin: VoxelGeneratorPlugin
[INFO] No importer registered for op: PillarScatterPlugin. Attempting to import as plugin.
[INFO] Searching for plugin: PillarScatterPlugin, plugin_version: 1, plugin_namespace:
[INFO] Successfully created plugin: PillarScatterPlugin
[INFO] No importer registered for op: DecodeBbox3DPlugin. Attempting to import as plugin.
[INFO] Searching for plugin: DecodeBbox3DPlugin, plugin_version: 1, plugin_namespace:
[INTERNAL_ERROR] Validation failed: static_cast<size_t>(num_classes_) * 2 * 4 == anchors_.size()
/opt/trt_oss_src/TensorRT/plugin/decodeBbox3DPlugin/decodeBbox3D.cpp:79
[ERROR] std::exception
[ERROR] ModelImporter.cpp:740: While parsing node number 58 [DecodeBbox3DPlugin → “output_boxes”]:
[ERROR] ModelImporter.cpp:741: — Begin node —
[ERROR] ModelImporter.cpp:742: input: “cls_preds”
input: “box_preds”
input: “dir_cls_preds”
output: “output_boxes”
output: “num_boxes”
op_type: “DecodeBbox3DPlugin”
attribute {
floats: 0
floats: -32
floats: -0.6
floats: 32
floats: 32
floats: 0.6
type: FLOATS
attribute {
i: 2
type: INT
attribute {
f: 0.78539
type: FLOAT
attribute {
f: 0
type: FLOAT
attribute {
f: 0.1
type: FLOAT
attribute {
floats: -0.139
type: FLOATS
attribute {
floats: 0.238
floats: 0.239
floats: 0.378
floats: 0
type: FLOATS
[INFO] Using optimization profile max shape: (1, 25000, 4) for input: points
[ERROR] Unable to create engine
Just for clearness I’ve add the entire output from the command
Which Tensorrt version did you sync?
Could you use
git clone -b 22.02 https://github.com/NVIDIA/TensorRT.git TensorRT
as well to double check?
I used the one available from docker image from nvcr.io/nvidia/tao/tao-toolkit tag 4.0.0-pyt, which is 8.5.0
Is there any docker available with the TensorRT version you suggested or should I compile everything?
Because if I used the weight trained from KITTI dataseton the website and default configuration it works, but with mine (trained on a custom dataset) it doesn’t.
which tao-converter did you use?
In my case, I download TAO Converter | NVIDIA NGC
Also, there is no tao-converter in tao-toolkit docker image!
Actually it is present in the image that I referred above and it’s the last version:
Anyway I’ve tried the conversion even using the tao-converter binary that you linked and it doesn’t work neither using the latest version nor oldest one and the error is still the same
As seen above, there is tao-converter inside the tao pytorch docker.
To narrow down the error
Could you build and replace the libnvifer_plugin.so inside the tao pytorch docker ? Please refer to below step.
https://github.com/NVIDIA-AI-IOT/tao_toolkit_recipes/tree/main/tao_pointpillars/tensorrt_sample
cd TensorRT
git submodule update --init --recursive
mkdir -p build && cd build
cmake .. -DCUDA_VERSION=$CUDA_VERSION -DGPU_ARCHS=$GPU_ARCHS
make nvinfer_plugin -j$(nproc)
make nvinfer_plugin_static -j$(nproc)
cp libnvinfer_plugin.so.8.2.* /usr/lib/$ARCH-linux-gnu/libnvinfer_plugin.so.8.2.3
cp libnvinfer_plugin_static.a /usr/lib/$ARCH-linux-gnu/libnvinfer_plugin_static.a
More, please check if you run notebok successfully. Also, please make sure if you can use the official etlt file from ngc as well.
So guys, I’ve found the problem! Basically, in my setup I’ve decided to have one value for anchor_rotations since in my dataset there is no rotation, which leads to an array of 1 element, but the converter works only if there are two values specified.
I do not know whose responsible for the development of this framework, but for future release I highly suggest to permit to specific no rotation in even if it is a rare case. Also because I had to redone the training, which is not ideal.
