Hi Team,
we followed following instruction on installation of tao toolkit on AWS instance. however after installation when we run tao info… we are not getting mask_rcnn option withing the option.
https://docs.nvidia.com/tao/tao-toolkit/text/running_in_cloud/running_tao_toolkit_on_aws.html
Configuration of the TAO Toolkit Instance
task_group: [‘model’, ‘dataset’, ‘deploy’]
format_version: 3.0
toolkit_version: 5.0.0
published_date: 07/14/2023
how do we configure tao toolkit to get this option?
On this page Running TAO Toolkit on an AWS VM - NVIDIA Docs ,
Below is an old version. Sorry for not updating it.
wget --content-disposition https://api.ngc.nvidia.com/v2/resources/nvidia/tao/cv_samples/versions/v1.2.0/zip -O cv_samples_v1.2.0.zip
unzip -u cv_samples_v1.2.0.zip -d ./cv_samples_v1.2.0 && cd ./cv_samples_v1.2.0
Please refer to https://docs.nvidia.com/tao/tao-toolkit/text/tao_toolkit_quick_start_guide.html???
Below will download latest 5.0 notebook.
wget --content-disposition https://api.ngc.nvidia.com/v2/resources/nvidia/tao/tao-getting-started/versions/5.0.0/zip -O getting_started_v5.0.0.zip
unzip -u getting_started_v5.0.0.zip -d ./getting_started_v5.0.0 && rm -rf getting_started_v5.0.0.zip && cd ./getting_started_v5.0.0
Thank you for the above update. it’s working now.
we are trying to run an Action recognition using TAO ActionRecognitionNet … first testing with a sample dataset to make sure everything works… however, stuck on the following step :
any help why its giving this error?
Did you follow the default notebook? For this error, please double check the dataset. Please try to run the default notebook and default dataset.
Yes, there is no modification done we just followed the default notebook and it downloaded the default dataset. however, it can not convert video to a png file it gives the above error.
Please try to check why the shell script failed to run well against the dataset.
The source code is in
# Copyright (c) 2021 NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a copy
# of this software and associated documentation files (the "Software"), to deal
# in the Software without restriction, including without limitation the rights
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
# copies of the Software, and to permit persons to whom the Software is
# furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all
# copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
This file has been truncated. show original
I recall that other user did not meet this kind of issue.
I think “preprocess README” is not expected. Maybe it is related to the path.
we modify the path and then it started working…
import os
os.chdir(‘tao_toolkit_recipes/tao_action_recognition/data_generation’)
import os
current_working_directory = os.getcwd()
print(current_working_directory)
so what could be the error in the default notebook.?
Could you save the notebook as .html file and share with us?
After modification we still stuck on training error.
actionrecognitionnet (1).html (832 KB)
Thank you … however we are using this file to train model… following tutorial from
https://www.youtube.com/watch?v=9cSyNtpIqLc
print(“Train RGB only model with PTM”)
!tao model action_recognition train \
-e $SPECS_DIR/train_rgb_3d_finetune.yaml \
#-r $RESULTS_DIR/rgb_3d_ptm \
results_dir=$RESULTS_DIR/rgb_3d_ptm \
-k $KEY \
model.rgb_pretrained_model_path=$RESULTS_DIR/pretrained/actionrecognitionnet_vtrainable_v1.0/resnet18_3d_rgb_hmdb5_32.tlt \
model.rgb_pretrained_num_classes=5
should we be using different file ?
Can you share the yaml file?
This file is actually output_dir: /results/rgb_3d_ptm .
For workaround, please change
to
results_dir: /results/rgb_3d_ptm
system
Closed
August 30, 2023, 2:00am
15
