I’ve been experimenting creating my own agent harness purely to better understand - there are a lot of good (open source) harnesses out there, but for me doing myself is often the way to truely understand.
Eventually it turned into something I’ve started using daily, so I figured I could share as well (and named it tauergon in short).
I’m truely just releasing this as concept - I think there are a couple of nice ideas - but not a polished nice UI system.
To ensure its working I’ve been running SWE Verified, looks like I have 67% with a Qwen 3.6 27b NVFP4 (although I will not be able to officially submit/get this verified based on new submission rules - not academia). (Update: running official validator locally shows almost identical pass rate)
Key ideas:
- tau agent fully capable of modifying itself - you want it changed, use it to change (and test) itself
- full agentic loop with tools
- tried to heavily optimiye for local AI:
- maximizing prompt/prefix cache re-use to get fast loop times
- multiple levels of llm response postprocessing, fixing, validating, rejecting (i.e. extracting toolcalls from reason/content, etc.)
- fork tool to spawn (synchronous) subagent utilizing parents kv cache
- dream loop for continous self improvement
- pure python, zero dependancies (0!) - all you need is python (I tested 3.12.3 and 3.13.5)
- will run very easy on almost anything recent
- you can “see” (and change) the full end to end in code without diving into complex modules
Warning:
- This is dangerous and can execute arbitrary code (i.e. bash) - if you give it passwordless sudo even that - you should only use this experimentally in a sandboxed environment
Requirements:
- OpenAI compatible endpoint
- Python (3.12.3 and 3.13.5 tested)
I’m currently using this as a daily driver for a lot of my stuff:
- coding (some other proejcts I’m working on like a worldbuild, some local training, etc. …)
- configuring my systems, testing new models (and ways to serve them)
- playing with ways todo tools different (different file edit approaches, web search,
Notes:
- I am using a local searxng and crawl4ai to improve results - but it will work without them
- As you see in my hardware spec below I’m typically going for larger contexts (200k) - its not (yet) super context optimizes - but maybe something you’d like to ask it todo to itself ;-)
- I am currently running SWE Verified with it (and qwen 3.6 27b for now) - time consuming, but will publish as I have it
- I’ve been running this with different model classes (nemotron, qwen, gemma) mainly with llama.cpp and vllm (briefly tensorrt and sglang), this is currently my main driver (but that changes weekly):
Have fun! Experiment! What its really nice for is to ask it to modify itself…
PC (to get interactive work done quickly - mostly single session):
Debian 13
Nvidia RTX 5090
cuda_13.3.0_610.43.02_linux.run
model is sakamakismile/Qwen3.6-27B-Text-NVFP4-MTP, llama-benchy rates it around 10k/sec pp and 150+/sec decode
docker-compose.yaml (depending on you system you might need to increase health check timeout for startup):
version: '3.8' volumes: # Shared volatile storage for the downloaded chat template template-share: services: # --- INIT CONTAINER: Downloads the template --- template-downloader: image: alpine:latest container_name: qwen-template-downloader volumes: - template-share:/tmp/chat-templates command: > sh -c "apk add --no-cache curl && echo 'Downloading froggeric chat template...' && curl -sL 'https://huggingface.co/froggeric/Qwen-Fixed-Chat-Templates/resolve/main/chat_template.jinja' -o /tmp/chat-templates/chat_template.jinja" # --- MAIN CONTAINER: vLLM Inference Engine --- qwen-vllm: image: vllm/vllm-openai:v0.22.1 container_name: qwen36-27b-nvfp4-mtp ports: - "8000:8000" shm_size: '32gb' ipc: host restart: always depends_on: template-downloader: condition: service_completed_successfully # Only starts after download finishes deploy: resources: reservations: devices: - driver: nvidia count: all capabilities: [gpu] volumes: - /home/alangeb/.cache/huggingface:/root/.cache/huggingface - template-share:/tmp/chat-templates # Mounts the shared volume containing the downloaded file environment: - VLLM_NVFP4_GEMM_BACKEND=flashinfer-cutlass - VLLM_USE_FLASHINFER_SAMPLER=1 - VLLM_USE_DEEP_GEMM=1 - PYTORCH_CUDA_ALLOC_CONF=expandable_segments:True command: - sakamakismile/Qwen3.6-27B-Text-NVFP4-MTP - --host - 0.0.0.0 - --port - "8000" - --served-model-name - model - --quantization - modelopt - --trust-remote-code - --language-model-only - --max-model-len - "200000" - --gpu-memory-utilization - "0.95" - --max-num-seqs - "2" - --max-num-batched-tokens - "2048" - --enable-chunked-prefill - --enable-prefix-caching - --kv-cache-dtype - fp8 - --calculate-kv-scales - --reasoning-parser - qwen3 - --tool-call-parser - qwen3_coder - --chat-template - /tmp/chat-templates/chat_template.jinja - --enable-auto-tool-choice - --enable-prompt-tokens-details - --speculative-config - '{"method":"qwen3_5_mtp","num_speculative_tokens":3}' - -tp - "1" - -pp - "1" # Watchdog implementation for hangs/engine death healthcheck: test: ["CMD-SHELL", "curl -f http://localhost:8000/health || exit 1"] interval: 15s timeout: 10s retries: 3 start_period: 300s
DGX Spark (to drive multiple parallel batch work sessions):
- sparkrun with @official/qwen3.6-27b-fp8-mtp-vllm
Alternative for NVFP4:
- cuda 13.0
- model is sakamakismile/Qwen3.6-27B-Text-NVFP4-MTP - I am using this here to stay close to my other systems config
- startup script (I realize I should probably not use v0.23.0… but it seems to work):
#!/bin/bash
# Start Qwen3.6-27B NVFP4-MTP via vLLM Docker (froggeric chat template)
# - NVFP4 quantization with MTP speculative decoding
# - Uses froggeric/Qwen-Fixed-Chat-Templates (v19) for improved agentic loop & KV cache
set -e
CONTAINER_NAME="qwen36-27b-nvfp4-mtp"
MODEL="sakamakismile/Qwen3.6-27B-Text-NVFP4-MTP"
IMAGE="vllm/vllm-openai:v0.23.0"
PORT=8000
HUGGINGFACE_CACHE="/home/alangeb/.cache/huggingface"
CHAT_TEMPLATE_URL="https://huggingface.co/froggeric/Qwen-Fixed-Chat-Templates/resolve/main/chat_template.jinja"
CHAT_TEMPLATE_LOCAL="/tmp/chat_template.jinja"
# Download chat template if not present or outdated
if [ ! -f "${CHAT_TEMPLATE_LOCAL}" ]; then
echo "Downloading froggeric chat template..."
curl -sL "${CHAT_TEMPLATE_URL}" -o "${CHAT_TEMPLATE_LOCAL}"
fi
# Stop existing container if running
if docker ps -a --format '{{.Names}}' | grep -q "^${CONTAINER_NAME}$"; then
echo "Stopping existing container ${CONTAINER_NAME}..."
docker stop "${CONTAINER_NAME}" 2>/dev/null || true
docker rm "${CONTAINER_NAME}" 2>/dev/null || true
fi
echo "Starting ${MODEL} on port ${PORT}..."
docker run \
--rm \
--name "${CONTAINER_NAME}" \
--gpus all \
-p ${PORT}:${PORT} \
-v ${HUGGINGFACE_CACHE}:/root/.cache/huggingface \
-v ${CHAT_TEMPLATE_LOCAL}:${CHAT_TEMPLATE_LOCAL} \
-e VLLM_USE_FLASHINFER_SAMPLER=1 \
-e VLLM_USE_DEEP_GEMM=1 \
-e PYTORCH_CUDA_ALLOC_CONF=expandable_segments:True \
${IMAGE} \
${MODEL} \
--host 0.0.0.0 \
--port ${PORT} \
--served-model-name model \
--quantization modelopt \
--linear-backend auto \
--trust-remote-code \
--language-model-only \
--max-model-len 200000 \
--gpu-memory-utilization 0.75 \
--max-num-seqs 2 \
--max-num-batched-tokens 2048 \
--enable-chunked-prefill \
--enable-prefix-caching \
--kv-cache-dtype fp8 \
--calculate-kv-scales \
--reasoning-parser qwen3 \
--tool-call-parser qwen3_coder \
--chat-template ${CHAT_TEMPLATE_LOCAL} \
--enable-auto-tool-choice \
--enable-prompt-tokens-details \
--speculative-config '{"method":"mtp","num_speculative_tokens":3}' \
-tp 1 \
-pp 1
