Tcpserversink streaming issue
I have following pipeline
and having issue with playing rtsp stream from it.
When I’m trying to play with ffplay rtsp://192.168.108.50:5400 get following error:
[rtsp @ 0x7fa54a40b200] CSeq 1 expected, 0 received.
rtsp://192.168.108.50:5400: Invalid data found when processing input
at the same time getting following warnings from container with pipeline:
instance-1  | 0:00:15.611843402     1 0x7f0708418b60 WARN         multisocketsink gstmultisocketsink.c:1079:gst_multi_socket_sink_socket_condition:<tcpserversink> [socket 0x7f067c003130] has error
instance-1  | 0:00:15.611886333     1 0x7f0708418b60 WARN         multihandlesink gstmultihandlesink.c:960:gst_multi_handle_sink_remove_client_link:<tcpserversink> [socket 0x7f067c003130] removing client 0x7f067c0020d0 because of error
Can you please help me to debug it?
hardware: amd64, docker, ubuntu
deepstream version: 6.2, python
• DeepStream Version
• TensorRT Version
can using filesink work? can the file play well?
• Hardware Platform (Jetson / GPU) Nvidia A2
• DeepStream Version 6.2
• TensorRT Version 8.5.2-1+cuda11.8 (not sure)
• NVIDIA GPU Driver Version 535.113.01
• Issue Type question
fanzh
yes, mkv file can be written and played
it is warning logs. could you share the whole logs? is the port taken? or is there any port permission issue? you can use the following command-line to check?
gst-launch-1.0 videotestsrc is-live=true ! jpegenc ! rtpjpegpay ! tcpserversink port=5400
