I have a stereo camera setup I want to do stereo depth mapping on using VisionWorks. For nvx_demo_stereo_matching the images are assumed to be undistorted and rectified.
Is there a way to do the undistortion and rectification using Argus, or should I use OpenCV?
If I need to use OpenCV is there an easy way to create a cv::GpuMat from a CUeglFrame?
Answered my second question, you can declare a GpuMat with a cudaAllocMapped buffer:
Example:
float4 *frame[2];
if(!cudaAllocMapped((void**)&frame[0], (void**)&frame[1], shared->width * shared->height * sizeof(float4)) )
ORIGINATE_ERROR("Failed to allocate CUDA memory for image\n");
/** Not shown, fill buffer with RGBAf image **/
cv::gpu::GpuMat gpu32(shared->height, shared->width, CV_32FC4, frame[1]);
cv::gpu::GpuMat gpu;
gpu32.convertTo(gpu, CV_8UC4);
cv::Mat rgb;
gpu.download(rgb);
cv::Mat bgr;
cv::cvtColor(rgb, bgr, cv::COLOR_RGB2BGR);
cv::imwrite("test.jpg", bgr);
