Tensorflow 2 SSD MobileNet V2 model inference on Deepstream 5.1
• Hardware Platform (Jetson / GPU) Any
• DeepStream Version 5.1
• TensorRT Version 7.*
I would like to use a SSD MobileNet V2 FPNLite 640x640 model originally trained in Tensorflow 2.
1) Tensorflow 2 → ONNX
I’ve converted the TF2 saved_model to ONNX using the tools of this repository.
But the output layers are adapted to use EfficientNMS_TRT op, which is not supported by TensorRT 7:
dez 07 18:12:02: ERROR: [TRT]: INVALID_ARGUMENT: getPluginCreator could not find plugin EfficientNMS_TRT version 1
dez 07 18:12:02: WARNING: [TRT]: onnx2trt_utils.cpp:220: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
dez 07 18:12:02: INFO: [TRT]: ModelImporter.cpp:135: No importer registered for op: EfficientNMS_TRT. Attempting to import as plugin.
dez 07 18:12:02: INFO: [TRT]: builtin_op_importers.cpp:3659: Searching for plugin: EfficientNMS_TRT, plugin_version: 1, plugin_namespace:
dez 07 18:12:02: ERROR: builtin_op_importers.cpp:3661 In function importFallbackPluginImporter:
dez 07 18:12:02: [8] Assertion failed: creator && "Plugin not found, are the plugin name, version, and namespace correct?"
dez 07 18:12:02: ERROR: Failed to parse onnx file
dez 07 18:12:02: ERROR: failed to build network since parsing model errors.
dez 07 18:12:02: ERROR: failed to build network.
Does anyone knows some workaround? (while keeping both the ONNX->TensorRT conversion step and inference on Deepstream)
2) Tensorflow 2 → UFF
Also tried the UFF conversion method described here.
Despite be able to convert to a UFF file, I think conversion was not fully sucessful as I’m not able to use it on DS. It generates an assertion error on TensorRT/plugin/nmsPlugin/nmsPlugin.cpp,82 when creating the engine.
UFF conversion just works for models trained on Tensorflow 1?
Please note that there is a new Deepstream 6.0 package.
It’s recommended to move to the latest release first.
For TensorFlow 2.x, it’s required to use the ONNX intermediate format rather than UFF.
As your finding, the EfficientNMS_TRT plugin needs TensorRT 8.0 library which is included in the JetPack 4.6.
Please upgrade your environment with Deepstream 6.0 + JetPack 4.6 and try it again.
