I downloaded the Inception V3 pre-trained model weight from https://storage.googleapis.com/download.tensorflow.org/models/inception_v3_2016_08_28_frozen.pb.tar.gz, and transformed it to uff format file by using
python3 /root/anaconda3/lib/python3.6/site-packages/uff/bin/convert_to_uff.py --input_file inception_v3_2016_08_28_frozen.pb
Then I changed TensorRT 5.1.5(version: 5.1.5) example samples/python/introductory_parser_samples/uff_resnet50.py to test TensorRT with using inception_v3_2016_08_28_frozen.uff , but I got the incorrect prediction,
Incorrectly recognized /mnt/nvidia/TensorRT-5.1.5.0/data/InceptionV3/reflex_camera.jpeg as clog
here is my code, I had changed correctly the label file class_labels.txt to imagenet_slim_labels.txt for Inception V3
# Copyright 1993-2019 NVIDIA Corporation. All rights reserved.
# NOTICE TO LICENSEE:
# This source code and/or documentation ("Licensed Deliverables") are
# subject to NVIDIA intellectual property rights under U.S. and
# international Copyright laws.
# These Licensed Deliverables contained herein is PROPRIETARY and
# CONFIDENTIAL to NVIDIA and is being provided under the terms and
# conditions of a form of NVIDIA software license agreement by and
# between NVIDIA and Licensee ("License Agreement") or electronically
# accepted by Licensee. Notwithstanding any terms or conditions to
# the contrary in the License Agreement, reproduction or disclosure
# of the Licensed Deliverables to any third party without the express
# written consent of NVIDIA is prohibited.
# NOTWITHSTANDING ANY TERMS OR CONDITIONS TO THE CONTRARY IN THE
# LICENSE AGREEMENT, NVIDIA MAKES NO REPRESENTATION ABOUT THE
# SUITABILITY OF THESE LICENSED DELIVERABLES FOR ANY PURPOSE. IT IS
# PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED WARRANTY OF ANY KIND.
# NVIDIA DISCLAIMS ALL WARRANTIES WITH REGARD TO THESE LICENSED
# DELIVERABLES, INCLUDING ALL IMPLIED WARRANTIES OF MERCHANTABILITY,
# NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE.
# LICENSE AGREEMENT, IN NO EVENT SHALL NVIDIA BE LIABLE FOR ANY
# SPECIAL, INDIRECT, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, OR ANY
# DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
# WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS
# ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE
# OF THESE LICENSED DELIVERABLES.
# U.S. Government End Users. These Licensed Deliverables are a
# "commercial item" as that term is defined at 48 C.F.R. 2.101 (OCT
# 1995), consisting of "commercial computer software" and "commercial
# computer software documentation" as such terms are used in 48
# C.F.R. 12.212 (SEPT 1995) and is provided to the U.S. Government
# only as a commercial end item. Consistent with 48 C.F.R.12.212 and
# 48 C.F.R. 227.7202-1 through 227.7202-4 (JUNE 1995), all
# U.S. Government End Users acquire the Licensed Deliverables with
# only those rights set forth herein.
# Any use of the Licensed Deliverables in individual and commercial
# software must include, in the user documentation and internal
# comments to the code, the above Disclaimer and U.S. Government End
# Users Notice.
# This sample uses a UFF ResNet50 Model to create a TensorRT Inference Engine
import random
from PIL import Image
import numpy as np
import pycuda.driver as cuda
# This import causes pycuda to automatically manage CUDA context creation and cleanup.
import pycuda.autoinit
import tensorrt as trt
import sys, os
sys.path.insert(1, os.path.join(sys.path[0], ".."))
import common
class ModelData(object):
# MODEL_PATH = "resnet50-infer-5.uff"
MODEL_PATH = "inception_v3_2016_08_28_frozen.uff"
INPUT_NAME = "input"
# INPUT_SHAPE = (3, 224, 224)
INPUT_SHAPE = (3, 299, 299)
# OUTPUT_NAME = "GPU_0/tower_0/Softmax"
OUTPUT_NAME = "InceptionV3/Predictions/Reshape_1"
# We can convert TensorRT data types to numpy types with trt.nptype()
DTYPE = trt.float32
# You can set the logger severity higher to suppress messages (or lower to display more messages).
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
# Allocate host and device buffers, and create a stream.
def allocate_buffers(engine):
# Determine dimensions and create page-locked memory buffers (i.e. won't be swapped to disk) to hold host inputs/outputs.
h_input = cuda.pagelocked_empty(trt.volume(engine.get_binding_shape(0)), dtype=trt.nptype(ModelData.DTYPE))
h_output = cuda.pagelocked_empty(trt.volume(engine.get_binding_shape(1)), dtype=trt.nptype(ModelData.DTYPE))
# Allocate device memory for inputs and outputs.
d_input = cuda.mem_alloc(h_input.nbytes)
d_output = cuda.mem_alloc(h_output.nbytes)
# Create a stream in which to copy inputs/outputs and run inference.
stream = cuda.Stream()
return h_input, d_input, h_output, d_output, stream
def do_inference(context, h_input, d_input, h_output, d_output, stream):
# Transfer input data to the GPU.
cuda.memcpy_htod_async(d_input, h_input, stream)
# Run inference.
context.execute_async(bindings=[int(d_input), int(d_output)], stream_handle=stream.handle)
# Transfer predictions back from the GPU.
cuda.memcpy_dtoh_async(h_output, d_output, stream)
# Synchronize the stream
stream.synchronize()
# The UFF path is used for TensorFlow models. You can convert a frozen TensorFlow graph to UFF using the included convert-to-uff utility.
def build_engine_uff(model_file):
with trt.Builder(TRT_LOGGER) as builder, builder.create_network() as network, trt.UffParser() as parser:
# Workspace size is the maximum amount of memory available to the builder while building an engine.
# It should generally be set as high as possible.
builder.max_workspace_size = common.GiB(1)
# We need to manually register the input and output nodes for UFF.
parser.register_input(ModelData.INPUT_NAME, ModelData.INPUT_SHAPE)
parser.register_output(ModelData.OUTPUT_NAME)
# Load the UFF model and parse it in order to populate the TensorRT network.
parser.parse(model_file, network)
# Build and return an engine.
return builder.build_cuda_engine(network)
def load_normalized_test_case(test_image, pagelocked_buffer):
# Converts the input image to a CHW Numpy array
def normalize_image(image):
# Resize, antialias and transpose the image to CHW.
c, h, w = ModelData.INPUT_SHAPE
return np.asarray(image.resize((w, h), Image.ANTIALIAS)).transpose([2, 0, 1]).astype(trt.nptype(ModelData.DTYPE)).ravel()
# Normalize the image and copy to pagelocked memory.
np.copyto(pagelocked_buffer, normalize_image(Image.open(test_image)))
return test_image
def main():
# Set the data path to the directory that contains the trained models and test images for inference.
data_path, data_files = common.find_sample_data(description="Runs a InceptionV3 network with a TensorRT inference engine.", subfolder="InceptionV3", find_files=["binoculars.jpeg", "reflex_camera.jpeg", "tabby_tiger_cat.jpg", ModelData.MODEL_PATH, "imagenet_slim_labels.txt"])
# Get test images, models and labels.
test_images = data_files[0:3]
uff_model_file, labels_file = data_files[3:]
labels = open(labels_file, 'r').read().split('\n')
# Build a TensorRT engine.
with build_engine_uff(uff_model_file) as engine:
# Inference is the same regardless of which parser is used to build the engine, since the model architecture is the same.
# Allocate buffers and create a CUDA stream.
h_input, d_input, h_output, d_output, stream = allocate_buffers(engine)
# Contexts are used to perform inference.
with engine.create_execution_context() as context:
# Load a normalized test case into the host input page-locked buffer.
test_image = random.choice(test_images)
test_case = load_normalized_test_case(test_image, h_input)
# Run the engine. The output will be a 1D tensor of length 1000, where each value represents the
# probability that the image corresponds to that label
# We use the highest probability as our prediction. Its index corresponds to the predicted label.
pred = labels[np.argmax(h_output)]
if "_".join(pred.split()) in os.path.splitext(os.path.basename(test_case))[0]:
print("Correctly recognized " + test_case + " as " + pred)
else:
print("Incorrectly recognized " + test_case + " as " + pred)
if __name__ == '__main__':
main()
Is there something wrong? Any idea would be appreciated.
