My requirement is to use tensorflow serving 1.15 on ampere architecture GPUs. For this I followed tutorial given here. But this does not provide any tensorflow serving related documents. I need to use tensorflow serving. I tried making a docker image as follows:
FROM nvcr.io/nvidia/tensorflow:20.06-tf1-py3 as base_build
RUN apt-get update && apt-get install -y --no-install-recommends \
automake \
build-essential \
ca-certificates \
curl \
git \
libfreetype6-dev \
libtool \
libcurl3-dev \
libzmq3-dev \
mlocate \
openjdk-8-jdk\
openjdk-8-jre-headless \
pkg-config \
python-dev \
software-properties-common \
swig \
unzip \
wget \
zip \
zlib1g-dev \
python3-distutils \
python-distutils-extra \
apt-get clean && \
rm -rf /var/lib/apt/lists/*
# Install python 3.6.
RUN add-apt-repository ppa:deadsnakes/ppa && \
apt-get update && apt-get install -y \
python3.6 python3.6-dev python3-pip python3.6-venv && \
rm -rf /var/lib/apt/lists/* && \
python3.6 -m pip install pip --upgrade && \
update-alternatives --install /usr/bin/python3 python3 /usr/bin/python3.6 0
# Make python3.6 the default python version
RUN update-alternatives --install /usr/bin/python python /usr/bin/python3.6 0
RUN curl -fSsL -O https://bootstrap.pypa.io/get-pip.py && \
python3 get-pip.py && \
rm get-pip.py
RUN pip3 --no-cache-dir install \
future>=0.17.1 \
grpcio \
h5py \
mock \
numpy \
portpicker \
requests \
--ignore-installed six>=1.12.0
# Set up Bazel
ENV BAZEL_VERSION 0.24.1
WORKDIR /
RUN mkdir /bazel && \
cd /bazel && \
curl -H "User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36" -fSsL -O https://github.com/bazelbuild/bazel/releases/download/$BAZEL_VERSION/bazel-$BAZEL_VERSION-installer-linux-x86_64.sh && \
curl -H "User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36" -fSsL -o /bazel/LICENSE.txt https://raw.githubusercontent.com/bazelbuild/bazel/master/LICENSE && \
chmod +x bazel-*.sh && \
./bazel-$BAZEL_VERSION-installer-linux-x86_64.sh && \
cd / && \
rm -f /bazel/bazel-$BAZEL_VERSION-installer-linux-x86_64.sh
# Build TensorFlow with the CUDA configuration
ENV CI_BUILD_PYTHON python
ENV LD_LIBRARY_PATH /usr/local/cuda/extras/CUPTI/lib64:/usr/local/cuda/lib64:/usr/local/cuda/lib64/stubs:/usr/include/x86_64-linux-gnu:/usr/lib/x86_64-linux-gnu:$LD_LIBRARY_PATH
ENV TF_NEED_CUDA 1
ENV TF_NEED_TENSORRT 0
ENV TENSORRT_INSTALL_PATH=/usr/lib/x86_64-linux-gnu
ENV TF_CUDA_VERSION=
ENV TF_CUDNN_VERSION=
# Fix paths so that CUDNN can be found: https://github.com/tensorflow/tensorflow/issues/8264
WORKDIR /
RUN mkdir /usr/lib/x86_64-linux-gnu/include/
RUN ln -s /usr/include/cudnn.h /usr/local/cuda/include/cudnn.h && \
ln -s /usr/lib/x86_64-linux-gnu/libcudnn.so /usr/local/cuda/lib64/libcudnn.so && \
ln -s /usr/lib/x86_64-linux-gnu/libcudnn.so.${TF_CUDNN_VERSION} /usr/local/cuda/lib64/libcudnn.so.${TF_CUDNN_VERSION}
# For backward compatibility we need this line. After 1.13 we can safely remove
# it.
ENV TF_NCCL_VERSION=
# Set TMP for nvidia build environment
ENV TMP="/tmp"
# Download TF Serving sources (optionally at specific commit).
RUN curl -sSL --retry 5 https://github.com/tensorflow/serving/archive/refs/tags/1.15.0.tar.gz | tar --strip-components=1 -xzf -
RUN curl -sSL --retry 5 https://github.com/tensorflow/tensorflow/archive/590d6eef7e91a6a7392c8ffffb7b58f2e0c8bc6b.tar.gz | tar -xzf -
FROM base_build as binary_build
# Build, and install TensorFlow Serving
ARG TF_SERVING_BUILD_OPTIONS="--config=release"
RUN echo "Building with build options: ${TF_SERVING_BUILD_OPTIONS}"
ARG TF_SERVING_BAZEL_OPTIONS=""
RUN echo "Building with Bazel options: ${TF_SERVING_BAZEL_OPTIONS}"
RUN ln -s /usr/local/cuda/lib64/libcusolver.so.*.*.* /usr/local/cuda/lib64/libcusolver.so.${TF_CUDA_VERSION}
RUN ln -s /usr/local/cuda/lib64/stubs/libcuda.so /usr/local/cuda/lib64/stubs/libcuda.so.1 && \
LD_LIBRARY_PATH=/usr/local/cuda/lib64/stubs:${LD_LIBRARY_PATH} \
bazel build --color=yes --curses=yes --config=cuda --copt="-fPIC"\
${TF_SERVING_BAZEL_OPTIONS} \
--verbose_failures \
--output_filter=DONT_MATCH_ANYTHING \
${TF_SERVING_BUILD_OPTIONS} \
tensorflow_serving/model_servers:tensorflow_model_server && \
cp bazel-bin/tensorflow_serving/model_servers/tensorflow_model_server \
/usr/local/bin/ && \
rm /usr/local/cuda/lib64/stubs/libcuda.so.1
# Build and install TensorFlow Serving API
RUN bazel build --color=yes --curses=yes \
tensorflow_serving/tools/pip_package:build_pip_package && \
bazel-bin/tensorflow_serving/tools/pip_package/build_pip_package \
/tmp/pip && \
pip --no-cache-dir install --upgrade \
/tmp/pip/tensorflow_serving_api_gpu-*.whl && \
rm -rf /tmp/pip
FROM binary_build as clean_build
# Clean up Bazel cache when done.
RUN bazel clean --expunge --color=yes && \
rm -rf /root/.cache
CMD ["/bin/bash"]
But I’m getting follwoing error:
ERROR: Skipping 'tensorflow_serving/model_servers:tensorflow_model_server': error loading package 'tensorflow_serving/model_servers': in /tensorflow_serving/tensorflow_version.bzl: in /root/.cache/bazel/_bazel_root/6666cd76f96956469e7be39d750cc7d9/external/org_tensorflow/tensorflow/tensorflow.bzl: Encountered error while reading extension file 'cuda/build_defs.bzl': no such package '@local_config_cuda//cuda': Traceback (most recent call last):
File "/root/.cache/bazel/_bazel_root/6666cd76f96956469e7be39d750cc7d9/external/org_tensorflow/third_party/gpus/cuda_configure.bzl", line 1266
_create_local_cuda_repository(repository_ctx)
File "/root/.cache/bazel/_bazel_root/6666cd76f96956469e7be39d750cc7d9/external/org_tensorflow/third_party/gpus/cuda_configure.bzl", line 1033, in _create_local_cuda_repository
_find_libs(repository_ctx, cuda_config)
File "/root/.cache/bazel/_bazel_root/6666cd76f96956469e7be39d750cc7d9/external/org_tensorflow/third_party/gpus/cuda_configure.bzl", line 637, in _find_libs
_find_cuda_lib("cusolver", repository_ctx, cpu_valu..., <2 more arguments>)
File "/root/.cache/bazel/_bazel_root/6666cd76f96956469e7be39d750cc7d9/external/org_tensorflow/third_party/gpus/cuda_configure.bzl", line 589, in _find_cuda_lib
find_lib(repository_ctx, [("%s/%s" % (based...))], ...)))
File "/root/.cache/bazel/_bazel_root/6666cd76f96956469e7be39d750cc7d9/external/org_tensorflow/third_party/gpus/cuda_configure.bzl", line 563, in find_lib
auto_configure_fail(("None of the libraries match th...)))
File "/root/.cache/bazel/_bazel_root/6666cd76f96956469e7be39d750cc7d9/external/org_tensorflow/third_party/gpus/cuda_configure.bzl", line 325, in auto_configure_fail
fail(("\n%sCuda Configuration Error:%...)))
Cuda Configuration Error: None of the libraries match their SONAME: /usr/local/cuda/lib64/libcusolver.so.11
WARNING: Target pattern parsing failed.
ERROR: error loading package 'tensorflow_serving/model_servers': in /tensorflow_serving/tensorflow_version.bzl: in /root/.cache/bazel/_bazel_root/6666cd76f96956469e7be39d750cc7d9/external/org_tensorflow/tensorflow/tensorflow.bzl: Encountered error while reading extension file 'cuda/build_defs.bzl': no such package '@local_config_cuda//cuda': Traceback (most recent call last):
INFO: Elapsed time: 0.866s
INFO: 0 processes.
FAILED: Build did NOT complete successfully (0 packages loaded)
currently loading: tensorflow_serving/model_servers
