I want to inference Caffe model trained by DIGITS on Jetson via TRT 4 with C++ api. So far I made TensorFlow models trained by DIGITS work but not Caffe.
The problem is in the parser method (ICaffeParser->parse(…)).
The C++ CaffeParser can not parse model made by DIGITS successfully. I am trying to do simple MNIST LeNet network for grayscale images… So I trained Caffe model in DIGITS (I left the default description of the network) and ran inference via DIGITS. It is working. Now I downloaded the snapshot and trying to parse it in C++ but the Data type layer which is DIGITS using is not supported by TRT.
auto blobNameToTensor = mCaffeParser->parse(aFilePrototxt.toUtf8(), aFileCaffemodel.toUtf8(), *trtNetwork, aNetworkDataType);
In logs:
could not parse layer type Data
The default site definition from newest Digits:
# LeNet
layer {
type: "Data"
top: "data"
top: "label"
data_param {
batch_size: 64
include { stage: "train" }
layer {
type: "Data"
top: "data"
top: "label"
data_param {
batch_size: 32
include { stage: "val" }
layer {
# Use Power layer for input scaling
bottom: "data"
top: "scaled"
type: "Power"
power_param {
# 1/(standard deviation on MNIST dataset)
scale: 0.0125
layer {
type: "Convolution"
bottom: "scaled"
top: "conv1"
param {
lr_mult: 1
param {
lr_mult: 2
convolution_param {
num_output: 20
kernel_size: 5
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "Pooling"
bottom: "conv1"
top: "pool1"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: "Convolution"
bottom: "pool1"
top: "conv2"
param {
lr_mult: 1
param {
lr_mult: 2
convolution_param {
num_output: 50
kernel_size: 5
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "Pooling"
bottom: "conv2"
top: "pool2"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: "InnerProduct"
bottom: "pool2"
top: "ip1"
param {
lr_mult: 1
param {
lr_mult: 2
inner_product_param {
num_output: 500
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "ip1"
top: "ip1"
layer {
bottom: "ip1"
top: "ip2"
param {
lr_mult: 1
param {
lr_mult: 2
# Since num_output is unset, DIGITS will automatically set it to the
# number of classes in your dataset.
# Uncomment this line to set it explicitly:
#num_output: 10
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "Accuracy"
bottom: "ip2"
bottom: "label"
top: "accuracy"
layer {
type: "SoftmaxWithLoss"
bottom: "ip2"
bottom: "label"
top: "loss"
exclude { stage: "deploy" }
layer {
type: "Softmax"
bottom: "ip2"
top: "softmax"
include { stage: "deploy" }
Is there a way how to redefine the input layers of type Data to be supported by TRT?
Thank you.
edit: Does not work with TRT5 too.
