In sampleSSD project, which is provided in samples, I have noticed a GPU memory leak for about +10 mb for every call of execute.
My goal was to build an ANN and allow it to do multiple inferences as long as it is needed.
So I have edited the source code of sampleSSD.cpp to make such approach.
if (!sample.build())
return gLogger.reportFail(sampleTest);
for (int i = 0; i < 100; ++i) // I've added the loop to do the multiple calls
// original code
if (!sample.infer()) // the nvinfer1::IExecutionContext::execute is called inside this function
if (!sample.teardown())
return gLogger.reportPass(sampleTest);
So after breaking down the problem I have noticed that the raising in GPU memory is coming from the command nvinfer1::IExecutionContext::execute.
Are there any suggestions how to avoid this problem or am I doing it wrong?
I have encountered the problem using:
cuda_10.0.130_411.31_win10
cudnn-10.0-windows10-x64-v7.6.3.30
TensorRT-6.0.1.5.Windows10.x86_64.cuda-10.0.cudnn7.6
I didn’t encounter the memory leak when using:
cuda_10.1.243_426.00_win10
cudnn-10.1-windows10-x64-v7.6.4.38
TensorRT-6.0.1.5.Windows10.x86_64.cuda-10.1.cudnn7.6
@nilshinn, I have a task to test it on linux too, can you provide information on what version you have installed and you encountered the problem with? with cuda 10.1 or cuda 10.0?
I used cuda 10.1,
cuda_10.1.243_418.87.00_linux.run
cudnn-10.1-linux-x64-v7.6.4.38.tgz
TensorRT-6.0.1.5.CentOS-7.6.x86_64-gnu.cuda-10.1.cudnn7.6.tar.gz
